3D Printing Requests
Discussion in 'Hobby Engineering' started by aXLe, Jun 16, 2013.
  1. 303-Acid
    303-Acid Member
    2,996
    Grantville, Vic
    This one's just slightly too big for my printer. I won't be cheap due to its size, parts, time to print. I'll leave it to others to quote.
    $12 plus post. Colours available: black, blue, white, clear.
  2. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    in your gearbox...grindin
    not to steal anything, so i'll offer the same price of $12 plus post, the only difference is the colour, i have dark blue.
    I've had a bit of a closer look, It'll take a whole roll of filament it seems, but that's okay, I'd do it for $120.
    I only have Dark blue at the moment for colour
  3. silverbullet
    silverbullet Member
    Apr 2, 2005
    2,002
    Marcoola, Sunshine Coast
    Not even 500g worth of filament there, i reckon about 350ish. I print a shitload of stuff, latest being mpcnc parts 3 layers with 60% infill.
  4. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    ah okay, i took a look, it's got quite a few pieces 14 if i remember right, and figured a smidge under $10 a piece. shrugs. I'm new to the 3d printing stuff.
  5. silverbullet
    silverbullet Member
    Apr 2, 2005
    2,002
    If you use S3D i think you can work it out by using preview, i've not tried that yet but i see in the options you can add filament cost and all that kind of stuff in one of the menus so i assume it would be able to tell you how many meters of filament in preview per job.
  6. gazza30
    gazza30 Member
    Aug 28, 2009
    1,119
    FNQ
  7. oRiCLe
    oRiCLe Member
    May 24, 2004
    179
    Sydney, NSW
    wow seems like alot of work for a 3d printer when you could drill holes for that :p, I can do this laser cut in black acrylic or mdf if you were interested tho
  8. gazza30
    gazza30 Member
    Aug 28, 2009
    1,119
    FNQ
    Cheers mate just came across them and was curious is all no idea about 3d printing cost or time involved.
    How much would you be asking for a 50 round block them made from acrylic?
    Thanks.
  9. iceyman
    iceyman Member
    Sep 15, 2010
    31
    Well in the new year ill get it done mate u may even have new colours then :D
  10. elcarter1
    elcarter1 Member
    Feb 24, 2007
    860
    I believe I have this Balco now sorted. Have done 3 x 16 hour prints with success.
    Anyone in SA that's in need of some PLA prints happy to give it a shot.
    Have some ABS here but not yet attempted.
  11. tasmik
    tasmik Member
    Oct 12, 2010
    215
  12. oRiCLe
    oRiCLe Member
    May 24, 2004
    179
    Sydney, NSW
    Would need to be printed in TPU flexible for it to work, I don't have any of that sorry nor the correct extruder to suit printing it.
  13. Madengineer
    Madengineer Member
    May 27, 2011
    14,802
    Is anybody able to do a few (12ish) items for me? Basically they're tiles (to make a real dungeons and dragons interact map) ahaha. They're only like, 100mm squared?
    Cheers
  14. pinchies
    pinchies Member
    Jun 4, 2009
    342
    3097, Melbourne
    Where are you located, and do you need them posted?
  15. Madengineer
    Madengineer Member
    May 27, 2011
    14,802
    Located bumfucknowhere :D
    Postage would be great, unless someone that does it is based in Albury or Wagga (I go there frequently)
    Cheers :)
  16. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,408
    Melbournish 3750
    how high do you need to go? if its not too high and there is no overhang cnc routing some wood, wax or foam might be cheaper and easier
  17. Madengineer
    Madengineer Member
    May 27, 2011
    14,802
    Each tile is about 5mm. Well we've started with 3d printing already. Unfortunately the person that started it has lost his 3d printer (kaput). So we wanna try and keep it all the same. I know it uses jack all material. And if it was all done and posted at the same time postage costs wouldn't be much
  18. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,408
    Melbournish 3750
    wait.... so are they completely flat? why didnt you just get some 5mm mdf and cut it up yourself.... or even 5mm foamcore which you can just cut with a stanley knife... colour me confused
    i wish you the best tho
  19. Madengineer
    Madengineer Member
    May 27, 2011
    14,802
    Plastic lasts longer and is more durable, plus the fact we'll have walls/stairs and stuff. It gets complicated. Haha
  20. psychobunny
    psychobunny Member
    Mar 30, 2006
    2,408
    Melbournish 3750
    Ok... i guess i just dont get it since i dont know dnd. Do you have a pic or a model that i can see as its now stuck in my head
