3D Printing Requests
Discussion in 'Hobby Engineering' started by aXLe, Jun 16, 2013.
  1. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
  2. m3k
    m3k Member
    Dec 29, 2007
    1,039
    super high detail might need resin - if you want it to picture perfect, i can print resin also.
    depends on size and colours etc
  3. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
    Probably looking at about 3 inches high, 2 inches wide, retaining correct proportions. Depth probably 2 or 3mm. Colours as close to the original as possible.
  4. m3k
    m3k Member
    Dec 29, 2007
    1,039
    yea ive thought about this- this project is a bit too tedious for me to do right now
  5. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
    No worries, thanks anyways. If you feel like picking up later down the track let me know. No particular rush.
  6. fureien
    fureien Member
    Apr 11, 2013
    104
    hi guys im looking to get a very simple rectangular frame/sidepanel printed for my itx case.
    think of it as an open rectangle (like picture frame). i plan to stretch a piece of mesh over it to create a DIY mesh panel so thats why the centre is entirely open
    the issue is it is a bit large (about 34cm x 26cm x 0.4cm) so unsure if it fits most printers. so may have to print it as 2 pieces?
    i have created the base model in tinkercad and have the glb/obj/stl files ready including screw holes etc
    can anyone help me and give me a quote on how much this would cost? i dont know anything about slicing sorry.
    i can also modify it to create more holes/gaps in the edge to make the whole thing more hollow. but hopefully 4mm of thickness isnt too bad in terms of materials required
    im based in sydney but happy to cover postage of course. its a flat sheet so would be easily posted
    alternatively if someone can point me to a cheap place that cuts a small piece of acrylic, that would be awesome too
    https://1drv.ms/u/s!AozRXSXj66CKgZsracSkVzCprbbpjg?e=a94AFl
    screenshot
    cheers
  7. m3k
    m3k Member
    Dec 29, 2007
    1,039
    I could just laser cut/engrave one out of acrylic if u want? have u thought about how you want to mount the mesh
    the acrylic is 3mm thick comes in a few colours and transparent
    my printers are max 30x30 it would need to be in multiple parts if you wanted it 3d printed instead of lasercut and you have far more color choice
    im estimating max $45 min $20
  8. fureien
    fureien Member
    Apr 11, 2013
    104
    yeah acrylic would be best. something in frosted white or smoke grey
    i just wasnt sure of the cost of acrylic and 3d printers were more proliferate that people having acrylic lasers at home lol :p
    i did a quick search on aliexpress to see if anyone offered it overseas and found something for about $50usd for 2 pieces. So price seems about right
    Any chance you can do 2 pieces (one for both sides)?
    no idea about mounting yet. i was just going to use double sided tape. cant think of a better way
  9. m3k
    m3k Member
    Dec 29, 2007
    1,039
    yea i can do two, if you provide an illustrator AI file it would be easier for me also; pm me
  10. Jumpingmanjim
    Jumpingmanjim Member
    Sep 20, 2008
    638
  11. Kosti
    Kosti Member
    Aug 19, 2001
    1,512
    Hey Printers
    I was given a busted up Tevo Tarantula today and has a quick look, it appears it was dropped or fell as most of the acrylic bits are cracked and broken, especially for the Z mount motor, so figured I'd get some items printed while I try to repair the electronics as it seems there was either a short on the 12V line or the heatbed drawed too much current and melted the connector on the control board maybe the board is completely fried, but will test this out soon
    Now I would like to get these items below printed in ABS, especially the support brackets and reinforced parts, some of the washers and mobo cover plate and case can be a suitable plastic and I'm also happy for these requests to be broken up with different people or if one person wants to take on the task to make costing easier than cool, as ideally someone in Sydney so I can collect or keep postage costs to a min
    So if you guys want to cost this up and let me know, I also have 4 or 5 rolls of of ABS spools if that helps keep the cost down as by the time these are printed, I should've fixed the electronic and ready to power it on and test print
    List below in no specific order
    https://www.thingiverse.com/thing:2757853 - Z mount including reinforced motor support for Tevo Tarantula
    https://www.thingiverse.com/thing:2572598 - Tevo Tarantula Bed Support note there is a version 2 here, but I think there was some instructions on the first version hence I've included both, but require V2 printed instead which is located here https://www.thingiverse.com/thing:2832758
    https://www.thingiverse.com/thing:2473848 - Tarantula Centre Bracket
    https://www.thingiverse.com/thing:2346783 - Interchangeable Dual Blower
    https://www.thingiverse.com/thing:2310971 - Tevo Tarantula electronics cover plate 9x13cm for 8cm fan
    https://www.thingiverse.com/thing:1439471 - Thumb Wheel X 4
    https://www.thingiverse.com/thing:3286845 - Washers for above
    https://www.thingiverse.com/thing:2523881 - Tevo Tarantula Z Stabilizer
    https://www.thingiverse.com/thing:2516091 - Tevo Tarantula Electronics Enclosure RPi Edition
    https://www.thingiverse.com/thing:2824233 - TEVO Tarantula electronics case/LCD Mount
    https://www.thingiverse.com/thing:2620858 - X-Rail Spool Mount
    https://www.thingiverse.com/thing:2761136 - This one has a lot of pieces to print, because I can't tell which is which at the moment I opted to just get them all printed and I will use what I need from the project
    Thanking you all in advance!
    Kosti
  12. Kosti
    Kosti Member
    Aug 19, 2001
    1,512
    FYI
    All my 3D Prints have been scheduled and taken care off thanks everyone for the PM'S
    m3k and isaakk like this.
  13. combatant3219
    combatant3219 Member
    Mar 23, 2013
    495
    Blackburn
    Wondering how much it would cost for someone to print me a pair of these adapters for my shp9500. Per the comments from others who have printed them, they should be printed at 99% scale.
    https://www.thingiverse.com/thing:2702058/makes
  14. tangcla
    tangcla Member
    Aug 22, 2001
    7,374
    Yep.
    Or just PM me, I'm happy to help out. I'm in Mount Waverley.
  15. tangcla
    tangcla Member
    Aug 22, 2001
    7,374
    PLA definitely out of the question - deforms at 50-60 degrees.
    PETG is about 80-90 (but still deforms in the car on a dashboard), ABS about 100-110 degrees. They're the three main types (before you get into the more exotic filaments).
    Depending on the flame (intensity and distance), ABS would be the best - but there's also the possibility of ABS being toxic when burned (releasing styrene).
  16. tangcla
    tangcla Member
    Aug 22, 2001
    7,374
    It will deform and melt, rather than combust.
  17. m3k
    m3k Member
    Dec 29, 2007
    1,039
    hey mate collapse all your posts into one -there is an edit button for a reason! yes 3d printed jigs can help you bend sheet metal etc without being specific about your application help will be very limited- there is tonnes of learning material on youtube and google on these kinds of applications
    plastics and fire never really mixed well in the past especially open flames- you can learn about engineering plastics and their melting and burning temperatures- how they perform near an open flame etc etc- which hold flames- which self extinguish after a while etc etc
    one reason 3d printer parts, especially, enclosures are often made with pet-g is because they tend to self-extinguish more than other options such as ABS even though abs has a higher melting temperature- its failure mode is more preferred in an electronic enclosure scinario so its not as simple as "what can withstand the most heat" rather is this plastic suitable for this application
    But your best bet is to speak to actual material scientists or engineers on the topic not just forum internet people when it comes to making stuff you plan to sell and mass produce later.
    also this thread is for people to request prints- throw an STL file up- and somebody will probably print it for very cheap compared to a public printing bureau - specifically as a community love kinda thing scratching backs making friends etc.
    StixStudios, garfield2k and tangcla like this.
  18. StixStudios
    StixStudios New Member
    Mar 22, 2021
    4
    :thumbup:
    No probs. All posts deleted.
  19. m3k
    m3k Member
    Dec 29, 2007
    1,039
    no sweat no need to delete them all just 3 + in a row is hard to read, hey and welcome to the forums :) best wishes :)
    also the whole "your best best to speak to engineers" i really hope it didnt come across as "ur not welcome to ask us at the forums" Just our info probably is not as awesome as a professionals :p but i learn tonnes from forums, you should def ask when you have a question tho- no such thing as dumb questions.. i think.. tho i've probably asked some dumb questions in the past hahah
  20. Gamelife
    Gamelife Member
    Jul 17, 2017
    29
    hi,
    is it still possible to request 3d prints here?
    looking to see if something like this is possible and what is required to request for it to be done:
    cheers
