3D Sound and Digital Cables - Why your games are in stereo only
Discussion in 'PC Audio' started by rawhide, Oct 25, 2005.
  1. thaFunkster
    thaFunkster New Member
    Jul 27, 2009
    441
    Very interesting thread, thanks rawhide.
    One thing: ASUS Xonar DX can encode DTS and Dolby Digital (D2X) if I am not mistaken.
    THat does mean you can run digital out, and still play games in surround, am I correct?
  2. mshagg
    mshagg Politburo
    May 8, 2007
    23,089
    Anything with DTS connect and/or Dolby Digial Live will encode your multi channel games into 5.1 discreet channels for digital output over SPDIF, yes.
    Cant comment on the xonar specifically but im sure someone can confirm :thumbup:
  3. aerospyke
    aerospyke Member
    Aug 10, 2005
    3,245
    Sydney NSW
    Isn't the Xonar the one that does DTSHD and DolbyHD encoding??
  4. thaFunkster
    Jul 27, 2009
    441
    Yeah, Ive got a DX.
    ITs almost exactly the same as the D2X, except I think it only encodes in Dolby Digital, not DTS, but for less than half the price, Im happy.
    And with a decent sound card, its better to run analogue out and decode with the card I am told anyway, so it shouldnt be an issue.
    If that's true, then the only time you would want to run digital out, is if you have a REALLY good receiver, in which case why bother with a good soundcard? You might as well just use onboard...
  5. mshagg
    mshagg Politburo
    May 8, 2007
    23,089
    If your receiver doesnt have analogue inputs for surround sound (i.e. only 2ch stereo input) then multi channel encoded digital is your only option for surround sound gaming.
    If you fall back to onboard for digital then you're back to square one with 2ch PCM output in most cases. Although my main rig has Realtek 889a with DDL capability on the motherboard :thumbup:
  6. thaFunkster
    Jul 27, 2009
    441
    Why cant O get a digital signal from Xonar to Z-5500s?
    Ok, I get you, makes sense.
    Slightly off topic, but can I ask something:
    I bought some Z-5500s, had an Audigy 2 ZS soundcard, run digital out (using an minijack to RCA adapter) but got nothing on the speakers.
    Ok, well, then the centre channel died on soundcard, so I figured it was broken.
    ...Bought myself a Xonar DX, tried digital out, still nothing, then the rear channel on the speakers dies. Ok, faulty control centre, cool.
    Soooo...Now I have got the warranty replacement for the speakers, new set seem to be working perfectly, buuuut...Still no digital signal.
    What the heck am I doing wrong?
    I have a (single) minijack to RCA adapter plugged into the mic/digi out port on soundcard, then the RCA cord is running to Control Centre, into the Coaxial in (only plug it fits into).
    Then I open up Xonar control software, check the "SPDIF out" box. But when I cycle through on the Logitech control centre, Coaxiacle says
    no digital data........
    Help pls.
  7. toolsncorpses
    toolsncorpses Member
    Jun 4, 2006
    1,174
    3862 VIC
    Why can't games output a dolby digital signal? The Vista control panel can.
  8. Plastik8
    Plastik8 Member
    Sep 8, 2003
    1,571
    For games to output Dolby Digital, they would need to encode it on the fly. You will require a sound card that has Dolby Digital Live (or something similar). See Mr Bubbles post a few spots up.
    In the Vista control panel, it is a pre-encoded signal - like a DVD or digital TV. Any sound card with digital output (SPDIF) only needs to send/copy this data out for your decoder to decode.
  9. toolsncorpses
    Jun 4, 2006
    1,174
    3862 VIC
    Okay.
    Hmm, well things sound 5.1-ish in Wolfenstein on my Sony AV Receiver. Definitely getting positional effects with dropping bullets and explosions...
  10. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,490
    I can confirm that my aging Auztentech X-Plosion correctly encodes positional audio output via DTS optical to my surround amp when HL2 is set to 5.1 speakers, hopefully your amp isn't just 'guessing' where the sound should be placed.
  11. toolsncorpses
    Jun 4, 2006
    1,174
    3862 VIC
    Well sound comes through all 5 speakers, but I wasn't sure if the front and rears were clones of eachother or not. I set Wolfenstein to 'surround' mode (there's also an option for 5.1 but this didn't sound any different) and bullets are specifically dropping on the rear left and rear right speakers, so I'm thinking it's all good :confused:. The receiver can upmix to 5.1 ProLogic II from stereo, but I've turned this off since it sounds odd except with music.
    Nevertheless the sound is great...
    edit Shit I can't tell anymore, all this fiddling with the receiver is driving me crazy. Did someone say if I buy a certain card I can do surround over digital?
    edit2 Bah seems if I set the games to stereo I get better positioning letting the amp do the work
  12. thaFunkster
    Jul 27, 2009
    441
  13. toolsncorpses
    Jun 4, 2006
    1,174
    3862 VIC
    Hmm I'm running an X-Fi chip as it is, I think it's a Fatality Pro or XtremeMusic (it's one of the larger boards and has a red light with a logo on the PCB), how do you know the X-Fi can do it? I'm still puzzling over whether this 5.1 is happening or not...
  14. iwnt2ovc
    iwnt2ovc Member
    Oct 13, 2009
    317
    Gippsland,Victoria
    all i do is run my soundcard into my denon avr4308ci receiver.
    I know its not a true 5.1 but it does the job.
    I also have the z5500 that i use with the analog cables.
    So what sound cards support dolby digital and so forth?
  15. thaFunkster
    Jul 27, 2009
    441
    All Xonar Cards can encode in Dolby Digital, and DTS for the more expensive ones.
    As for the X-Fi, I just had a look here:
    http://us.creative.com/products/product.asp?category=1&subcategory=208&product=15854&nav=1
    So it says analogue to digital conversion of analogue inputs, not exactly sure what that means, and whether it means just stereo digital or surround it does not specify.
    If it can do Dolby Digital, you will have to change that in your settings somewhere rather than just PCM format (stereo).
  16. toolsncorpses
    Jun 4, 2006
    1,174
    3862 VIC
    Well I messed around for hours and the best it gets is L, R, C, then SL and SR are L and R, as well, that is: when I do the channel test the rear speakers do nothing. I have no idea how the center gets in there. Seems PCM is three-channel? :confused:
  17. thaFunkster
    Jul 27, 2009
    441
    Maybe the rear channel on your soundcard has died. Or also double check the volume level of rear channel on both windows settings and your amp
  18. toolsncorpses
    Jun 4, 2006
    1,174
    3862 VIC
    The volume is the same as the front speakers/it's all fine. The rear speakers work when I do the Dolby Digital test. I'm guessing my problem now is what the thread is all about....
    edit - okay, now it's working, I think it was my receiver. Still says its PCM48 on the receiver but there is specific sounds in the rear speakers now.
    By the way for X-Fi users there's a checkbox for Dolby Digital in the "supported formats" tab of SPDIF-out Properties. I don't know if that means it encodes onthefly...
  19. thaFunkster
    Jul 27, 2009
    441
    Ok, glad it worked out.
    If you can play games in digital surround, then yes it does :)
