4.1 audio out of macbook pro via toslink
Discussion in 'Apple Desktop Hardware/Software' started by justakid, Mar 7, 2012.
  1. justakid
    justakid Member
    1,532
    Hey guys, I'm trying to connect my boston 7500g 4.1 speakers to my MBP. I am using a optical to coaxial adapter and every thing works except for the rare speakers.
    That is the only time the rare speakers work is when I am watching a movie with Dolby audio. Anyone know of a way to have audio come out of all the speakers at all time?
  2. adktz
    adktz Member
    Feb 5, 2010
    229
    From my own testing, I'm pretty certain that audio will only come out of the rear channels when you're sending a Dolby encoded (e.g. movies) signal. At all other times it's stereo; just what the headphone jack provides.
    justakid
    justakid Member
    1,532
    Thanks for the response adktz, seems that way :(
  4. gr8bob
    gr8bob Member
    May 12, 2009
    130
    You'll probably want to head into the Audio MIDI Setup application and see if the speakers are properly configured. :)
    justakid
    justakid Member
    1,532
    thanks for the suggestion gr8bob, unfortunately, the only options there are for stereo speakers - the rest are greyed out
  6. Jazper
    Jazper Member
    Jul 28, 2001
    2,670
    Melbourne Australia
    I spent a long time trying to work this out..
    You have a few options -
    1. route the audio through a "proxy" and back through the optical (see soundflower) http://cycling74.com/products/soundflower/
    2. use an app that specifically drives the optical out (eg xbmc/boxee/plex)
    3. surrender
  7. [KEi]SoVeReIgN
    [KEi]SoVeReIgN Member
    Feb 20, 2002
    8,618
    Yep, also sometimes some stereo systems will have a 4/5/6 channel stereo option where it mixes the front two channels across all the others.
