4870x2 case issue
Discussion in 'Newbie Lounge' started by Burgerknife, Sep 24, 2008.
  1. Burgerknife
    Burgerknife New Member
    Jul 30, 2008
    9
    Hey all, I was just wondering if sum1 could help me out with a small issue i have, i need to know if the 4870x2 will fit in a cooler master centurion 5 on a gigabyte P35 motherboard (I dont know if motherboard size matters but i know i have 1 PCIe 16x slot on it). Dont know heaps about hardware but i'm pretty sure thats all i need to know, thx very much in advance :)
  2. DiGiTaL MoNkEY
    DiGiTaL MoNkEY Inverted Monkey
    Jun 28, 2005
    26,894
    Melbourne, Victoria
    I dont have that case, but i can let you know the length of the card... its approximately ~10.5" Inches long.
    Burgerknife
    Jul 30, 2008
    9
    Is there anyway that i can check myself, i just don't know if it will interfere with other slots and stuff. Will it be hard for me to check myself? It's just my computer is in a REALLY hard place to unplug and i don't wanna unplug it for nothing.
  4. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    ADL/SA The Monopoly State
    theres a thing we used to use back in primary school called a RULER.
    Burgerknife
    Jul 30, 2008
    9
    A ruler doesn't take into account curves in the card nor does it take into account obstructions. Thanks for bein a smart arse though :)
  6. simboes
    simboes Member
    Mar 29, 2004
    6,406
    St Leonards 2065
    should fit into most newer cases midi-tower and up. but yeah best to measure manually. or search google for a list of compatible cases ;)
  7. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    explain where a curve on the card might interfere that a ruler couldnt measure out?
    its not like youre trying to fit some 4D object into 2D space here...
  8. simboes
    simboes Member
    Mar 29, 2004
    6,406
    St Leonards 2065
    lol yeah, the motherboard is what fits the width of the card, and should be fine there, the case you only have to worry about the length of the card which is 1 dimension!!! :D
  9. vashez
    vashez New Member
    Jun 9, 2008
    44
    Shitney
    It will fit. Built a computer in one of these towers a month ago.
    Burgerknife
    Jul 30, 2008
    9
    Thx very much for the helpful feed back, i'm sorry if it sounded stupid, thats why i posted in the Newbie section where it says you won't get flamed and no question 2 stupid... obviously mine was to stupid so sorry for that.
    Thx again all for the help
