4G/LTE SMA Antenna F/ Huawei E5186 ADVICE?!
Discussion in 'Networking, Telephony & Internet' started by SSJ4, Mar 6, 2018.
  1. Ratzz
    Ratzz Member
    Mar 13, 2013
    9,205
    Cheltenham East 3192
    I have a 4G Optus Huawei E5573 modem you are welcome to borrow, which works very well, but I'm 30 mins drive from you.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    Thats all good mate thanks for the offer, I am hoping someone has the newer huawei b525s-65a that has the ethernet ports on it. I have alot of stuff I like to run wired for.
  3. Ratzz
    Ratzz Member
    Mar 13, 2013
    9,205
    No problem. I thought you just wanted to test reception to compare to yours, to see if yours was fritzed.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    I do. But same model or latest one. Spent some time on tech support tonight... went through the usual "plz sir reset your modem" bs. So I hard reset the modem and set to defaults again. They said if the issue continues tomorrow to call back and THEN they can open a support ticket for me.
    I am tempted to just front up to a store and see if they will give me a new one on the spot. But the issue is I bought it second hand lol, so dunno if they will let me. Maybe they wont check my plan and see it doesnt include the modem haha.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    Update this morning.
    Hard resetting, factory reset and putting the device in 4g only has doubled the download and given a 1mbps upload increase.
    But hard to know if the difference in speed is just times of day.
    Just speed tested my Kogan sim in my phone.
    88.4 down / 39.8 up. Did about 5 tests in various parts of the room, speeds are consistent. I was hitting over 100 easily on the kogan sim last night so I assume there is just more traffic. But the upload speed difference is considerable... hoping it improves more. I cant really find any settings related to bandwidth control, but maybe the modem is connecting to a different band of 4G than my phone does?
  6. hawpinghaxbag
    hawpinghaxbag Member
    Jun 6, 2005
    5,241
    Your mum's place
    With a samsung phone yu can check band by dialing *#0011# and change/force bands with *#2263#
    Dunno about the modem
    Also if i was streaming i'd want to avoid Optus 2300mhz (band 40) as it is time division duplex and you are fighting more download orientated users for upload bandwidth but it can still end up being better if other bands are congested
    Also if you can try locking your modem to specific bands and testing it, for example with Telstra if i lock my phone to Band 7 instead of leaving it on auto where i live my speed increases from ~40mbps to 200+
  7. dave_dave_dave
    dave_dave_dave Member
    Mar 17, 2004
    2,867
    Gold Coast
    I'm not sure if anyone has mentioned this already.
    The modem you are using (assuming you still have the same one as the first post) does not support Band 28 (700MHz) or 40 (2300MHz), which Optus use. That might possibly be hurting your performance.
    I've been playing round with a D-link DWR-921 recently, they are a fairly impressive basic cat 4 (150/50) 4G modem/router and they support all Optus and Telstra bands.
    Should be able to pick one up under $200 on ebay, just make sure its the C3 hardware revision.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    Youre thinking of the e5186s-22a the e5186s-61a supports 700 and 2600.
    I did look into the dlink, band coverage and none gigabit ethernet put me off.
  9. dave_dave_dave
    Mar 17, 2004
    2,867
    Gold Coast
    I was just going off the specs you put in the first post. Looks like the 61a variant you have probably isn't the issue then.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    Ahh true my mistake mate.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    UPDATE:
    Apply 1x Antenna boi.
    AFTER:
    Surely those antenna didnt just give me a 40mbps increase? maybe it has something todo with resetting the modem. Interesting that my Upload went down. I'll have to experiment with placement.
    I really need to know why I am not getting the 40mps Upload out of the same sim but in my phone though...
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    Interesting, moving the antenna around is actually affecting performance.
    Good to know they actually do something and arent a waste of money lol.
    SSJ4
    SSJ4 Member
    May 16, 2017
    813
    24mins later? 4G is so weird.
  14. hawpinghaxbag
    Jun 6, 2005
    5,241
    Your mum's place
    There should be band number, LTE bandwidth and CA mode along with those signal values, they may provide a few clues as to why its jumping around
    Also can be best to test at 4am in the morning when the tower is consistently dormant
  15. tHor's_Hammer
    tHor's_Hammer Member
    Nov 6, 2002
    19
    I was having stability problems with my Huawei E5183 - kept losing connection after I moved 500m up the road. Was told to shut down, take out SIM and re-insert. Seems to have fixed the problem?
  16. koopz
    koopz Member
    Dec 27, 2001
    2,046
    Qld
    All good mate. The Comms industry here in Aus is a shit show.
    ACMA needs all the help they can get atm.
    in fact... I think the ACMA is in serious need of reform
  17. koopz
    koopz Member
    Dec 27, 2001
    2,046
    Qld
    personally... I'd prefer if those of us in the industry could perform ACMA audits on a contractual basis for ACMA so we could ping these clowns.
    My mind boggles every time I walk into a JB Hifi retail store.
  18. blued
    blued Member
    Apr 29, 2008
    238
    Your modem is cat-6 which means it only has carrier aggregation on the downstream.
    The s6 is cat-9 which means it has both up and downstream.
    Test the s6 and see if that gives better upstream speeds.
    A good way of testing whether it’s worthwhile investing in a decent external antenna (think roof mounted directional) is to compare the modem at your home vs. standing below the nearest tower. You may or may not be connecting to that tower from home but at least its an indicator. Your speeds don’t sound bad so you might just be wasting money for minimal gain.
    In my view spend the cash on a better modem as that may get you better upload. Test this with your s6. If you just want to spend cash then just go and get a cat-9 ac800s.
  19. wowbigkingfish
    wowbigkingfish New Member
    Nov 7, 2018
    3
    On the topic of the B525s-65a, does anyone know how to force it to just look at Band 40? I managed to be able to do it with the previous modem before upgrading to this one. I am with Optus on a speed limited plan, and band 40 get's me 12 Dwn. The other bands only give me 5.
