4K HDMI 2.0 remote switches - any actually work?
Discussion in 'Audio Visual' started by Azrael, Jun 7, 2019.
  1. Azrael
    Azrael Member
    8,715
    Ok, tl;dr time. Need a 4K HDMI switch that is actually capable of switching a 4K input without glitching out all the time. Needs to be IR and have discrete commands for changing to specific inputs, rather than a Next/Prev system, and have 4+ inputs.
    Been through a few of the cheaper ones on eBay and a couple from Kogan, but none actually sync up on 4K. All of them do this sort of glitching:
    Anyone have one that actually works?
  2. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    847
    Central Coast
  3. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    140,292
    Omicron Persei 8
    I've had this issue before with iQ4 and hdmi....turned out to be the cable.
  4. nico6
    nico6 Member
    Sep 9, 2005
    1,551
    melb.vic.au
    Did you use the HDMI cable included with the IQ4K? (That might be a new thing - I got mine about 2 weeks ago)
  5. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    140,292
    Omicron Persei 8
    The Foxtel installer did everything and just used my existing cables. I think in the end I did go back to the Foxtel provided one, or maybe just another better cable than my original ....but bottom line was changing the cable fixed it for me.
  6. Kow
    Kow Member
    Aug 2, 2001
    4,788
    Redlands, Bris QLD
    Most of the time if you are running 4k you will need 2.0 cables, considering the bandwidth required. Especially 4k60. I recently went through this process, it would do 4k then either go black sometimes or have green sparklies. Cables fixed it.
    Also note some splitters say 4K but they only do 4k 25/30hz. You need to specifically look for 4K 60hz if you want to run that.
    Azrael
    Azrael Member
    8,715
    In that video above I’m running brand new HDMI 2.0 cables :(
    Have another switch coming to test out.
  8. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    140,292
    Omicron Persei 8
    Yep, that's the symptoms I experienced, but mostly just cutting out.
  9. Kow
    Kow Member
    Aug 2, 2001
    4,788
    Redlands, Bris QLD
    what is the model of the switch and the tv model?
    Azrael
    Azrael Member
    8,715
    So it seems that this cheaper Simplecom switch works:
    Like $30 on eBay, where even some of the $60-80 ones wont.
  11. the_antipop
    the_antipop Member
    Jun 11, 2005
    1,774
    Gold Coast
    What inputs are going into the switch?
    Azrael
    Azrael Member
    8,715
    ATV4k, Xb1S, Switch and Steamlink.
