600ltr In Wall Tank (UPDATED 22/05/11 NEW FISH)
Discussion in 'Pets & Animals' started by n3wbi379, Dec 10, 2009.
  1. pugsley
    pugsley Member
    Jul 22, 2002
    7,602
    North of Brisvegas!
    I like the picture frame idea.
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Thanks James....
    Yer it will have some kind of framing like a pic frame.
    The builder was hinting at a nice aluminum finish maybe.
  3. dingdong555
    dingdong555 Member
    Feb 28, 2008
    2,176
    Australia, Perth
    Yeah, it'd look nice in aluminium depending what the inside of your house will be :)
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Well the house will be a black and white theme..... White walls, black couches etc...
    So maybe am thing a black frame for it.
  5. sharkmutiny
    sharkmutiny Member
    Aug 23, 2006
    90
    This little project is looking great n3wbi379, keep up the good work... and the updates! :thumbup:
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Been a while guys since i posted in this thread.....
    Got a few things ready for the tank.
    Chiller & RO Unit
    50KG of black gravel
    Do you think 50kg of gravel will be enough for a 6 foot tank?
  7. Oosh
    Oosh Member
    Oct 31, 2002
    9,280
    I doubt it.
    I have ~100 liters of gravel in my 7x2x2.5, which is an average of ~7.5cm deep (I say average coz mountains and valleys are constantly being built by the fish), I'm not sure what the density is but each 9L bucket weighed considerable more than 9Kg (so it's not 1:1).
    Note: My gravel is on the deeper side, but assuming your tank is 6x2 foot at the base, 12sqft = ~11,148sqcm, x5cm deep gravel = ~55 liters.
    Edit: This page suggests (in a roundabout fashion) a gravel density of 0.05lb per cubic inch.
    Therefore: 72"x24"x2" = 3,456 cuin, x 0.05lbs = 173lbs, = ~78Kg.
    If all of the above info. is correct 50Kg of gravel would give you 3.25cm depth. So unless you tanks is 18" wide of less (4.25+cm gravel depth), I'd buy another 25-50kg.
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Thanks buddy.....
    Just as i thought..... Dude you know how expensive this gravel is LOL... Oh well... Prob buy another 30kg.
    Edit: yes it is a 6x2x2.
  9. shon982
    shon982 New Member
    Feb 18, 2008
    313
    Brisbane, Cashmere
    ah depends how thick substrate you want
    ive got 60KG and my tank is 2 metres long and 50cm wide and its perfect, i'd even prefer having less than the 60KG,
    but its all personal preference i guess or depends what kind of fish you keep
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Will be a cichlid set up.... those sucker love moving gravel LOL.
  11. japes
    japes Member
    Sep 8, 2007
    6,540
    Sunshine Coast
    50kg should do it, but referencing that I use 60kg of sand in my 6x2x2 doesn't mean much as the weight varies.
    This is a Malawi Cichlid setup, correct? With that substrate, what are your plans for buffering the RO Water (which I can't say I totally understand, given buffering up tap-water has no negative effects compared to softening, which is nearly pointless) up to a suitable pH/gH/kH? Edit: I can see large limestone? rockwork in the background of one of your photos, I just imagine that having a substrate like Calcium Carbonate would do the job more effectively.
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Correct.. Malawi Cichlid setup.
    What i use to get my KH & GH up are these 2 products:
    Seachem Malawi Buffer and Seachem Cichlid Lake Salt.
    What you can see in the back ground is texas holey rock.
    Will be buying more for my 6 foot.
    This is my my current 4 foot.
  13. leroyxx
    leroyxx Member
    May 31, 2006
    2,200
    Horsham, Victoria
    Oh for sure, i have given up trying to keep gravel flat in my cichlid tank, he just keeps moving it till its where hes happy with it. :p
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    UPDATE
    Been a while since iv posted in this thread, been busy.
    Tank has arrived some time now.
    Was in its place but the base of the stand aint flat... Builder coming out to fix it soon.
    Have pics of the tank up late today. :D
  15. pugsley
    pugsley Member
    Jul 22, 2002
    7,602
    North of Brisvegas!
    Still waiting!!! :p
  16. shon982
    shon982 New Member
    Feb 18, 2008
    313
    Brisbane, Cashmere
    Pics or it didnt happen :p
  17. terroristone
    terroristone Member
    Apr 16, 2006
    2,170
    Melb 3030
    i second that!
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    GRRRRRRRRRRRRRRRRRRRRRRRRRRR
    Photobucket is down.... FFS.
    It happened boys LOL
  19. Micah.
    Micah. Member
    Apr 8, 2009
    232
    North Brisbane
    http://www.overclockers.com.au/pix/
    There you go much better than Photobucket :D
    n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,619
    Melb
    Sorry but am a photobucket fan, plus my album is there too... Should be up soon i hope.
