780ti Classified - Paste or tape?
Discussion in 'Video Cards & Monitors' started by Madengineer, May 26, 2016.
  1. Madengineer
    Madengineer Member
    May 27, 2011
    14,784
    Hey guys,
    Yes it is an easy question, yes I could easily check right now, but no I'm not going to because I don't have the interface material to replace it with.
    So my first question is, does the EVGA Classified (780Ti) use tape or paste?
    Secondly, if it uses paste, which is the best to use?
    I read a couple of comments saying you shouldn't use CPU paste on video cards?
    I'm beginning to think it's a TIM issue I've got with the card, as tonight it reached 99 degrees (again, I've read comments where people have had them at 75-80 max under load).
    Thoughts?
  2. nope
    nope Member
    May 8, 2012
    4,173
    Tipshitswitchitin Queeersland
    ANY thermal paste is better than nothing but i always used to use article silver on my builds gl :thumbup:
  3. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,401
    Paste on the gpu, pads on the mem. Unless it's a bad mount then changing the paste will only net you a few degrees at best. Whilst you're ordering the paste you might as well grab some 0.5mm and 1mm thermal pads and replace the stock ones.
    Paste wise I try to use one that's non conductive (I've been using Arctic MX-4) on GPU's. AS5 is fine for CPU's but if you're not careful and over apply its just asking for trouble on a GPU. You'll end up with something like this guy did.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,784
    Sounds good. Cheers. If i take the fan off, can i reuse the pads (worst case scenario? ) or do i absolutely replace all?
  5. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,401
    If you're careful you can generally re-use them but pads are only a few dollars (get the EK ones). So might as well grab some.
  6. nope
    nope Member
    May 8, 2012
    4,173
    Thanks for reminding me i needed some new pads :thumbup:
  7. havabeer
    havabeer Member
    Dec 12, 2010
    7,312
    i'm 99% sure NO manufacturer uses tape to mount their heat sinks to the gpu
  8. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,401
    My 6600gt had tape, think it was Leadtek brand :lol:
  9. nope
    nope Member
    May 8, 2012
    4,173
    ebay has some very cheap stuff beware though :thumbup:
    Madengineer
    Madengineer Member
    May 27, 2011
    14,784
    Wasnt going to use ebay. Haha.
    Going to the city today, so was going to pick some up while there.
    Also, evga don't void warranty for removing the hsf do they?
  11. josh1990
    josh1990 Member
    Mar 18, 2014
    1,605
    Albury, NSW
    No, they don't. Unless your removal of the hsf is what caused the issues. Best brand for watercooling warranty
  12. Bertross
    Bertross Member
    Feb 2, 2009
    13,908
    East Gipps
    Arctic MX-4 is good.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,784
    So get this! Go to the local computer store this morning... And the guy literally refuses to sell me pads for the memory, because 'it's too much of a risk that I'll screw the card' (he said he refuses to sell them to consumers because of this).
    So I just told him I'd just buy them online then and walked out. Damn it was infuriating!
  14. Bertross
    Bertross Member
    Feb 2, 2009
    13,908
    East Gipps
    what a fukstick. why is he selling it then lol.
  15. C-BuZz
    C-BuZz Member
    Jan 24, 2002
    5,205
    Melb, East
    What makes him so qualified to install them over someone who walks in?
    Does he have a degree in installing memory pads on GPU's :confused:
  16. BBITS
    BBITS Member
    Oct 18, 2007
    925
    Brisbane Southside
    Hope that wasn't the store you bought the card from sunshine!
  17. congoh
    congoh Member
    Jan 18, 2002
    7,498
    Melbourne, not too far from Monash Uni.
    He probably charges for labour in a similar way phone stall selling screen protectors sells/installs screen protector.
    Madengineer
    Madengineer Member
    May 27, 2011
    14,784
    This. He doesn't actually sell them. When i enquired how much it was he'd charge for it... $49 plus the cost of the pads and tim...
    It was ridiculous. And no. I didn't buy the card from him. I got it second hand here. :)
    Its a flawless card. It's just running much hotter than I'd like it to :(
  19. WJR
    WJR (Banned or Deleted)
    Mar 11, 2005
    859
    Barrelaide
    Wow, what a flog....I'd never go back to that shop again. It isn't rocket science pulling a cooler off and putting some paste or tape on.
