8TB drive smart just checking info with you guys
Discussion in 'Storage & Backup' started by Revenger, Jan 23, 2020.
  1. Revenger
    Revenger Member
    Aug 7, 2002
    4,023
    Armadale / Perth
    I am cleaning off the first 8TB drive I got and am hoping to use it in my nas which is a Synology on hybrid Raid 5.
    I notice the main attribute smart values are good though in the statistics tab it shows 51 reported uncorrectable errors.
    Here is the full log of the drive so don't know exactly what to make of this stat.
    Apart from ta couple stats and the fact the drive sounds fairly grindy like older drives it appears in good condition though.
    So mby someone more knowledgeable in smart stats can advise.
    Code:
    smartctl 6.6 2017-11-05 r4594 [x86_64-w64-mingw32-w10-b18362] (sf-6.6-1)
    Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Model Family:     Western Digital Red
    Device Model:     WDC WD80EFZX-68UW8N0
    Serial Number:    VK1G833Y
    LU WWN Device Id: 5 000cca 3b7d4931b
    Firmware Version: 83.H0A83
    User Capacity:    8,001,563,222,016 bytes [8.00 TB]
    Sector Sizes:     512 bytes logical, 4096 bytes physical
    Rotation Rate:    5400 rpm
    Form Factor:      3.5 inches
    Device is:        In smartctl database [for details use: -P show]
    ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
    SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
    Local Time is:    Wed Jan 22 23:19:41 2020 WAST
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    AAM feature is:   Unavailable
    APM level is:     164 (intermediate level without standby)
    Rd look-ahead is: Enabled
    Write cache is:   Enabled
    DSN feature is:   Unavailable
    ATA Security is:  Disabled, NOT FROZEN [SEC1]
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status:  (0x80)    Offline data collection activity
                        was never started.
                        Auto Offline Data Collection: Enabled.
    Self-test execution status:      (   0)    The previous self-test routine completed
                        without error or no self-test has ever
                        been run.
    Total time to complete Offline
    data collection:         (  101) seconds.
    capabilities:              (0x5b) SMART execute Offline immediate.
                        Auto Offline data collection on/off support.
                        Suspend Offline collection upon new
                        command.
                        Offline surface scan supported.
                        Self-test supported.
                        No Conveyance Self-test supported.
                        Selective Self-test supported.
    SMART capabilities:            (0x0003)    Saves SMART data before entering
                        power-saving mode.
                        Supports SMART auto save timer.
    Error logging capability:        (0x01)    Error logging supported.
                        General Purpose Logging supported.
    Short self-test routine
    recommended polling time:      (   2) minutes.
    Extended self-test routine
    recommended polling time:      (1083) minutes.
    SCT capabilities:            (0x003d)    SCT Status supported.
                        SCT Error Recovery Control supported.
                        SCT Feature Control supported.
                        SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
      1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
      2 Throughput_Performance  P-S---   129   129   054    -    124
      3 Spin_Up_Time            POS---   154   154   024    -    449 (Average 407)
      4 Start_Stop_Count        -O--C-   099   099   000    -    4765
      5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
      7 Seek_Error_Rate         PO-R--   100   100   067    -    0
      8 Seek_Time_Performance   P-S---   128   128   020    -    18
      9 Power_On_Hours          -O--C-   099   099   000    -    7655
     10 Spin_Retry_Count        PO--C-   100   100   060    -    0
     12 Power_Cycle_Count       -O--CK   100   100   000    -    1304
     22 Helium_Level            PO---K   100   100   025    -    100
    192 Power-Off_Retract_Count -O--CK   087   087   000    -    15940
    193 Load_Cycle_Count        -O--C-   087   087   000    -    15940
    194 Temperature_Celsius     -O----   176   176   000    -    34 (Min/Max 14/47)
    196 Reallocated_Event_Count -O--CK   100   100   000    -    0
    197 Current_Pending_Sector  -O---K   100   100   000    -    0
    198 Offline_Uncorrectable   ---R--   100   100   000    -    0
    199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                                ||||||_ K auto-keep
                                |||||__ C event count
                                ||||___ R error rate
                                |||____ S speed/performance
                                ||_____ O updated online
                                |______ P prefailure warning
    General Purpose Log Directory Version 1
    SMART           Log Directory Version 1 [multi-sector log support]
    Address    Access  R/W   Size  Description
    0x00       GPL,SL  R/O      1  Log Directory
    0x01           SL  R/O      1  Summary SMART error log
    0x02           SL  R/O      1  Comprehensive SMART error log
    0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
    0x04       GPL,SL  R/O      8  Device Statistics log
    0x06           SL  R/O      1  SMART self-test log
    0x07       GPL     R/O      1  Extended self-test log
    0x08       GPL     R/O      2  Power Conditions log
    0x09           SL  R/W      1  Selective self-test log
    0x10       GPL     R/O      1  NCQ Command Error log
    0x11       GPL     R/O      1  SATA Phy Event Counters log
    0x12       GPL     R/O      1  SATA NCQ Non-Data log
    0x15       GPL,SL  R/W      1  Rebuild Assist log
    0x21       GPL     R/O      1  Write stream error log
    0x22       GPL     R/O      1  Read stream error log
    0x24       GPL     R/O    256  Current Device Internal Status Data log
    0x25       GPL     R/O    256  Saved Device Internal Status Data log
    0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
    0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
    0xe0       GPL,SL  R/W      1  SCT Command/Status
    0xe1       GPL,SL  R/W      1  SCT Data Transfer
    SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
    No Errors Logged
    SMART Extended Self-test Log Version: 1 (1 sectors)
    Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
    # 1  Short offline       Completed without error       00%      7480         -
    # 2  Short offline       Completed without error       00%         6         -
    SMART Selective self-test log data structure revision number 1
     SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
        1        0        0  Not_testing
        2        0        0  Not_testing
        3        0        0  Not_testing
        4        0        0  Not_testing
        5        0        0  Not_testing
    Selective self-test flags (0x0):
      After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    SCT Status Version:                  3
    SCT Version (vendor specific):       256 (0x0100)
    SCT Support Level:                   1
    Device State:                        Active (0)
    Current Temperature:                    34 Celsius
    Power Cycle Min/Max Temperature:     32/34 Celsius
    Lifetime    Min/Max Temperature:     14/47 Celsius
    Under/Over Temperature Limit Count:   0/0
    SCT Temperature History Version:     2
    Temperature Sampling Period:         1 minute
    Temperature Logging Interval:        1 minute
    Min/Max recommended Temperature:      0/60 Celsius
    Min/Max Temperature Limit:           -40/70 Celsius
    Temperature History Size (Index):    128 (14)
    Index    Estimated Time   Temperature Celsius
      15    2020-01-22 21:12    45  **************************
      16    2020-01-22 21:13    44  *************************
      17    2020-01-22 21:14    44  *************************
      18    2020-01-22 21:15    43  ************************
      19    2020-01-22 21:16    43  ************************
      20    2020-01-22 21:17    42  ***********************
      21    2020-01-22 21:18    42  ***********************
      22    2020-01-22 21:19    41  **********************
      23    2020-01-22 21:20    41  **********************
      24    2020-01-22 21:21    40  *********************
      25    2020-01-22 21:22    40  *********************
      26    2020-01-22 21:23    40  *********************
      27    2020-01-22 21:24    39  ********************
      28    2020-01-22 21:25    39  ********************
      29    2020-01-22 21:26    39  ********************
      30    2020-01-22 21:27    38  *******************
     ...    ..(  2 skipped).    ..  *******************
      33    2020-01-22 21:30    38  *******************
      34    2020-01-22 21:31    37  ******************
      37    2020-01-22 21:34    37  ******************
      38    2020-01-22 21:35    36  *****************
     ...    ..(  3 skipped).    ..  *****************
      42    2020-01-22 21:39    36  *****************
      43    2020-01-22 21:40    35  ****************
     ...    ..(  5 skipped).    ..  ****************
      49    2020-01-22 21:46    35  ****************
      50    2020-01-22 21:47    34  ***************
     ...    ..(  6 skipped).    ..  ***************
      57    2020-01-22 21:54    34  ***************
      58    2020-01-22 21:55    33  **************
     ...    ..( 12 skipped).    ..  **************
      71    2020-01-22 22:08    33  **************
      72    2020-01-22 22:09    32  *************
     ...    ..( 32 skipped).    ..  *************
     105    2020-01-22 22:42    32  *************
     106    2020-01-22 22:43    31  ************
     ...    ..( 28 skipped).    ..  ************
       7    2020-01-22 23:12    31  ************
       8    2020-01-22 23:13    32  *************
       9    2020-01-22 23:14    32  *************
      10    2020-01-22 23:15    32  *************
      11    2020-01-22 23:16    33  **************
      12    2020-01-22 23:17    33  **************
      13    2020-01-22 23:18    34  ***************
      14    2020-01-22 23:19    45  **************************
    SCT Error Recovery Control:
               Read:     70 (7.0 seconds)
              Write:     70 (7.0 seconds)
    Device Statistics (GP Log 0x04)
    Page  Offset Size        Value Flags Description
    0x01  =====  =               =  ===  == General Statistics (rev 2) ==
    0x01  0x008  4            1304  ---  Lifetime Power-On Resets
    0x01  0x018  6     28249482795  ---  Logical Sectors Written
    0x01  0x020  6       125079033  ---  Number of Write Commands
    0x01  0x028  6     27007862646  ---  Logical Sectors Read
    0x01  0x030  6       159080770  ---  Number of Read Commands
    0x01  0x038  6     27560173700  ---  Date and Time TimeStamp
    0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
    0x03  0x008  4            3045  ---  Spindle Motor Power-on Hours
    0x03  0x010  4            3045  ---  Head Flying Hours
    0x03  0x018  4           15940  ---  Head Load Events
    0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
    0x03  0x028  4          172964  ---  Read Recovery Attempts
    0x03  0x030  4               0  ---  Number of Mechanical Start Failures
    0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
    0x04  0x008  4              51  ---  Number of Reported Uncorrectable Errors
    0x04  0x010  4              69  ---  Resets Between Cmd Acceptance and Completion
    0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
    0x05  0x008  1              34  ---  Current Temperature
    0x05  0x010  1              38  N--  Average Short Term Temperature
    0x05  0x018  1              34  N--  Average Long Term Temperature
    0x05  0x020  1              47  ---  Highest Temperature
    0x05  0x028  1              14  ---  Lowest Temperature
    0x05  0x030  1              43  N--  Highest Average Short Term Temperature
    0x05  0x038  1              20  N--  Lowest Average Short Term Temperature
    0x05  0x040  1              37  N--  Highest Average Long Term Temperature
    0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
    0x05  0x050  4               0  ---  Time in Over-Temperature
    0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
    0x05  0x060  4               0  ---  Time in Under-Temperature
    0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
    0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
    0x06  0x008  4               0  ---  Number of Hardware Resets
    0x06  0x010  4            1191  ---  Number of ASR Events
    0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                    |||_ C monitored condition met
                                    ||__ D supports DSN
                                    |___ N normalized value
    SATA Phy Event Counters (GP Log 0x11)
    ID      Size     Value  Description
    0x0001  2            0  Command failed due to ICRC error
    0x0002  2            0  R_ERR response for data FIS
    0x0003  2            0  R_ERR response for device-to-host data FIS
    0x0004  2            0  R_ERR response for host-to-device data FIS
    0x0005  2            0  R_ERR response for non-data FIS
    0x0006  2            0  R_ERR response for device-to-host non-data FIS
    0x0007  2            0  R_ERR response for host-to-device non-data FIS
    0x0008  2            0  Device-to-host non-data FIS retries
    0x0009  2            1  Transition from drive PhyRdy to drive PhyNRdy
    0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
    0x000b  2            0  CRC errors within host-to-device FIS
    0x000d  2            0  Non-CRC errors within host-to-device FIS
  2. fad
    fad Member
    Jun 26, 2001
    2,386
    City, Canberra, Australia
    Looks like they are SCSI bus errors.
    The disk is fine and has no errors.
  3. power
    63,079
    run a FULL manufacturers disagnostic over it, SMART is almost useless. (yes this will take a long time, and yes it's worth it).
    https://www.ontrack.com/au/blog/2016/08/26/using-smart-tools-to-predict-hdd-failure-2/
    WDC DLG, if you can go for a version that runs off a bootable usb.
    https://support.wdc.com/downloads.aspx?lang=en
    The fact that SMART has picked up anything means there may be a major issue, whether it's the physical hdd or the logic board.
    terrastrife likes this.
  4. fad
    fad Member
    Jun 26, 2001
    2,386
    Sometimes it's just a bad cable. Change them out.
  5. power
    63,079
    this too! ironically less likely but i'd run the diag with the cable as is, maybe change and re-run. even change the port on the board. but hdd's tend to have a higher fail rate than many components.
    Revenger
    Revenger Member
    Aug 7, 2002
    4,023
    Armadale / Perth
    Extended smart checked out so added it in and rebuilding now.
    Had a feeling it was mby cable errors or something as nothing was shown on the main attributes.
    If anything adding it to the nas is the best thing as if it has issues I can just swap it out with a replacement 8tb and rebuild without worrying about data.
