adding a PCI slot on mobo
Discussion in 'Modding' started by tiro_uspsss, Jun 29, 2008.
  1. cvidler
    cvidler Member
    13,327
    Little bit serious there with the mask. The fumes are the fun bit of soldering, the burns sure aint.
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    yeah, the fumes were getting in the way :D
  3. ViPeR-7
    ViPeR-7 Member
    582
    Newcastle, NSW, Australia
    Insane. I love it :lol::D:thumbup:
  4. Rzeractor
    Rzeractor Member
    May 23, 2003
    5,135
    Cacapoopoopeepee
    Man I hope this all works in the end!
    Gunna suck if it doesn't :(
  5. FLB
    FLB Member
    Jan 30, 2003
    3,580
    Wicked stuff so far! Love the eye-piece pic!! :thumbup:
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    testing...
  7. dragonFLAME
    dragonFLAME Member
    Nov 18, 2002
    770
    Somewhere Cool
    can't wait...
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    UPDATE
    ok folks, follow along closely:
    - I never tested this mobo before I got it :( :D
    - I do not have the correct RAM for this mobo ATM (it needs DDR2 ECC+REG)
    - the mobo has four onboard diagnostic LEDs
    my thought 'process':
    1) if the mobo shows nothing on monitor when turned on with no RAM in it nor any card in my mod slot - then I presume: no RAM = no signal to monitor
    2) if no smoke comes from anywhere, especially the slot - thats a dam good start :rofl:
    3) the four diagnostic LEDs can show a plethora of combo's, thus a hugh range of problems... I looked up in the mobo manual &... all problems relate to RAM issues - except one, which pertains to the PCI ;)
    4) If I turn on the mobo without the LAN card in my mod-slot, & a particular diagnostic error is shown on LEDs - then this would be purely due to the fact that there is no RAM present - cause clearly the mobo isnt going to be able to tell if its had the PCI contacts/traces extented (which is essentially all that *any* slot is, until a card is plugged in).
    SO
    If I turn it on with the LAN card in, & the diagnostic LEDs have the same combo as when the mobo was without - imo, its a confirmation of sorts :D
    hope everyone followed my train of thought ;)
    that plus this:
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    BTW - dont look too closely as to what I was using as CPU 'coolers' :D
  10. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Northern Beaches, Sydney
    Looks like awesome progress! :thumbup: :D Congrats. Hope you can get some RAM soon.
    Question though - wouldn't those heatsinks be way too small for the CPUs? They can get hot even just at idle you know (with no heatsink)? :Paranoid:
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    the CPUs are essentially laptop/notebook CPUs ;) - u cant see it in the pic, but there is a big desktop fan running in the background, directed @ the mobo ;) :thumbup:
    I saw a figure recently RE: the CPUs - '31W' - so thats either their usage or their heat output - not much either way ;) :thumbup:
  12. Menthu_Rae
    Menthu_Rae Member
    Mar 19, 2002
    6,874
    Ah ok - yeah 31W... it's not a lot - but definitely wouldn't want to run them passive like that - good idea with the desk fan. They should have thermal shutdown on them anyway. :Pirate:
    Why is it so hard to get RAM? Is it the registered part that's a PITA?
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    I'm hell low on $$$ atm, that plus oz etailers like to price gouge when it comes to server stuff :thumbdn:
    I have found an etailer in the USA that ships international, so I will be buying from them when I get the $ :)
  14. Quan-Time
    Quan-Time Member
    Feb 27, 2002
    2,664
    Radelaide.
    just thought i would post quickly.. i read this thread the other day and surprise no one else has tried this or commented.
    I did this a few years back on an old amd mobo. It didnt work altho the pci slot did power things up as yous does. I put it down to the NB chipset not being enabled.
    I currently have a DFI lanparty ultra-d mobo that was NOT sli ready even tho it has 2x pci-e slots. i could run 2 vid cards no prob.. Turns out a simple pencil trick on the NB chip unlocks it ! now i can do sli, albiet 16x and 8x (i think its 8x, could be 4x.. dont use sli atm anyway !)
    at a guess, maybe you might end up having to do the same, or possibly a bios flash. Find the next higher mobo is your series that has all the bells and whistles and i suspect it will actually work.
    fingers crossed and goodluck !
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    the SLi would be running x8, x8 ;) :thumbup:
    so far I have no way of knowing/testing whether data works on my PCI slot - but power obviously does - which is what I wanted.. the i-RAM only needs power - no data :thumbup:
    having said that, the LAN cards 'activity' LED does a bit of blinking when the mobo is turned on - iirc, this is normal 'procedure' for any LAN card in a pc.. so maybe, just maybe data is working too ;) - heres to hoping, as that would make the mod all the more sweet! :D
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    if all goes to plan, i will be ordering RAM next week Monday :w00t: - & I'll be getting express shipping, so fingers-crossed it will be here end of next week! :D
  17. slamaa
    slamaa Member
    Jun 1, 2006
    2,048
    Reservoir, VIC
    Nice work, how does the iRAM work if it only needs power. Or is it connected via SATA or IDE etc?
  18. cvidler
    cvidler Member
    13,327
    SATA 1 charcharchar
  19. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    Ram for the mobo or Ram for I-Ram?
    tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,439
    RAM for mobo - the i-RAM already has 4x1GB of Samsung UCCC :D :thumbup:
