Adding Wireless to Desktop
Discussion in 'Networking, Telephony & Internet' started by Madengineer, Jan 18, 2019.
  1. Madengineer
    Madengineer Member
    May 27, 2011
    13,261
    Hey guys,
    Are USB wifi adapters as shit now as they were 5 years ago? I need to add wireless to my desktop, as the cable is inconvenient.
    What would be the go to adapter to use?
    I've only got a mini PCIe slot available (it's a Micro board)
    Cheers!
  2. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,236
  3. callan
    callan Member
    Aug 16, 2001
    4,798
    melbourne
    The usb ones work well, and have the added advantage that they have a cord so they can be moved to get the best reception.
    Callan
    Madengineer likes this.
    Madengineer
    Madengineer Member
    May 27, 2011
    13,261
    So I got one, and I've honest to god had nothing but problems with it. Constant drop outs. Can't find the network when I know it's there. Pain. In. The. Ass.
  5. callan
    callan Member
    Aug 16, 2001
    4,798
    melbourne
    Which one?
    Callan
  6. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,236
    Just got the netgear nighthawk A7000, it works well and is fast, disappointed to see that it doesn't support the higher AC bands (channels 100+), below that works well though and has good throughput.
    Madengineer
    Madengineer Member
    May 27, 2011
    13,261
    I got a netgear a6210. Supposed to be decent. I’ve got it on the extension lead, sitting above everything (trying to minimise direct intereference by devices physically sitting inbetween). The modem is literally sitting 4 metres away from it.
  8. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,236
    5ghz network? If so try moving the band to (say) 40
  9. callan
    callan Member
    Aug 16, 2001
    4,798
    melbourne
    I am probably unlucky, but I have never had a single piece of netgear equipment that didn't give me trouble. Not ONE.. hell, even a dumb gigabit switch didn't work properly with Win8.1 machines when they came out of sleep. Routers that would lock up or fail to reestablish passthrough VPN connections. WiFi repeaters that... don't. Rack switches that would drop MAC tables, network card drives that would shit the bed, "Bridges" that weren't true bridges. Life has been a lot easier since I stopped buying that brand.
    You might find some solace HERE - at least you'll know you're not alone. It's cold comfort I'm sure but I would suggest returning it and trying something else.
    Callan
  10. Hater
    Hater Member
    Nov 19, 2012
    3,688
    every laptop uses mini PCI-E wireless cards, they work fine
    send me your address and i'll throw one into an envelope for you if you want
    Mace likes this.
  11. Mace
    Mace Member
    Aug 16, 2001
    478
