Adobe Bridge file info help
Discussion in 'Photography & Video' started by EvilGenius, Mar 3, 2020.
  1. EvilGenius
    EvilGenius Member
    Apr 26, 2005
    10,694
    elsewhere
    Hi guys,
    Have a lot of batch work to do, generally use adobe bridge to do it. Requirements are for the document title to match the file name. So currently I need to batch rename, then apply a metadata template with basic data for all, then I have to go file by file and add the filename into the document title field. Is there a way to get bridge to do that automatically?
  2. Hater
    Hater Member
    Nov 19, 2012
    5,346
    with powershell it should be fairly straight forward
