After 6 months I opened up my case and gave it a clean...
Discussion in 'Overclocking & Hardware' started by DDsD, Feb 7, 2005.
  1. DDsD
    DDsD @DDsD
    8,866
    And look at that sexy insulating layer on my PAL8045 Heatsink :lol:
    Hosted by UGBox Image Store
    Unfortunately i didn't grab before/after temps, because the reason the pc was dissasembled was because i had some corrupt .sys files i was fixing.. so i figured id give it a clean while i was there.. boy did it need it :thumbup:
    Edit: linked to wrong pic :lol:
  2. mute
    mute Member
    Apr 17, 2003
    4,172
    Its good to give your case a good clean every now and then :)
    I used to have my PC on the floor (carpet) and it got dusty really quick. Now it's on my desk and all good.
    Another PC i have here which is a Celery 433 kept on giving off an alarm for CPU over temp protect. It was 80 degrees!
    Took off the CPU and gave the HSF a clean, now its down to around 40!
  3. Lulu
    Lulu Member
    Nov 27, 2004
    157
    Tasmania
    Why do you that of the case to fix software?
    DDsD
    DDsD @DDsD
    8,866
    Since you asked..
    I had a corrupt Mup.sys file in my Xp install, which made it so that i was unable to boot into windows in any mode (or even get to a dos prompt) this, which was then exacerbated by the inability of the WinXP cd to repair the file using auto-repair (the installer just hung after loading the scsi drivers) meant that there was no way to get access to the hard drive without taking it out of the system and putting it in another..
    So the case opens up.. Hard drive comes out, goes into my external USB HDD case.. which was then plugged into my laptop and i copied a good version of the file over the corrupt one.. fixing the problem..
  5. Deeman
    Deeman Vagrant.
    8,727
    That looks like my old rig - you do realise you're supposed to have the fan on the PAL8045 blowing upwards? Mine used to get dusty, but only on the outer edges of the sink...
    DDsD
    DDsD @DDsD
    8,866
    Yeah, i *used* to change the fan direction every month or two, to blow out, and suck out the dust which would inevitably gets trapped, Just this time.. it took alot longer to change than usual. Iirc the difference between sucking and blowing was about 5% Alpha has some thermal tests which illustrate in pdf format showing the difference on their site somewhere..
  7. MyDixiesNormous
    MyDixiesNormous Member
    Jan 21, 2003
    2,418
    Melb
    Just goes to show you how much of the surface area is exposed to the fan/
  8. bsbozzy
    bsbozzy Member
    Nov 11, 2003
    3,924
    I have to clean my slk900a every month or 2, exactly the same as that, dust layers
  9. hoopstar
    hoopstar Member
    2,278
    Adelaide..
    Even more disgusting when you realise that 95% of dust consists of dead human skin.. :tongue:
  10. Deeman
    Deeman Vagrant.
    8,727
    Skin?
    From dead humans?
    :sick:
  11. banshee
    banshee Member
    Sep 8, 2001
    1,695
    Springwood, West of Hell (Sydney, actually)
    Dead skin, from LIVE humans... YOU! :wired:
    I think some research found that by the time a mattress was 10 years old, 70% of it's weight is dead skin that flakes off as you sleep. Dustmites just LOVE the smogasboard. :D
  12. Reaper
    Reaper Member
    11,109
    Brisbane, Qld, Australia
    Aye laddy. Ye've got zombies for sure. I'd be putting a passwerd onto yer computer so as they cannae get excited by online videos of mummies undoing their wrappings.
  13. ludeking
    ludeking Member
    Oct 27, 2002
    1,561
    An appropriate comment from the 'Reaper'! hehehe.
    :weirdo:
  14. stroggos2k
    stroggos2k Member
    Dec 23, 2001
    6,316
    Rozelle, Sydney NSW
    I noticed the same thing when I had my Alpha, the best way to clean it was to simply wash it in hot water, bye bye dust!
  15. Deeman
    Deeman Vagrant.
    8,727
    That was what i did too.
    They stay warm for aaages too!
  16. stroggos2k
    stroggos2k Member
    Dec 23, 2001
    6,316
    Rozelle, Sydney NSW
    Yeah I only replaced my 8045 because the mounting nuts decided to thread themselves after a whole lot of remounts due to cleaning.
  17. ernest
    ernest Member
    Feb 28, 2002
    1,104
    Victoria Park, WA
    Heh, attack of the killer dust bunnies. As somebody else said, I chuck all my heat sinks into a tub of lukewarm water with morning fresh and go scrubadub. That is when I remember to. Heatsink cleaning is kinda like cleaning your pool - you can't be bothered with it until its too late and some monster composed wholy of some sort of blue green algal bloom is eating your neighbors cat.....or something to that effect. Its a crap job, but somebody has to do it, I wish we had Mexicans here.
  18. The Beast
    The Beast Member
    3,524
    Back down under!
    Yeah works for my 8045 too, but the motherboard and CPU take AGES to dry.
  19. SKiB
    SKiB Member
    Aug 19, 2002
    839
    37°48'28.8S 145°7'8.04"E
    comments like that are sure to confuse people who arn't quite familiar with the whole troubleshooting process
  20. stroggos2k
    stroggos2k Member
    Dec 23, 2001
    6,316
    Rozelle, Sydney NSW
    Good one :lol:
