air flow with multiple radiators
Discussion in 'Extreme and Water Cooling' started by Will S, Jan 14, 2020.
  1. Will S
    Will S Member
    Aug 15, 2003
    5,258
    Coniston (Wollongong)
    Lian li 011 Dynamic with a full loop through GPU and CPU
    Say a 360 at the top and a 360 at the rear ( dual chamber so basically front rear ) and 2 fans at the bottom making 8 fans
    1/ All fans blowing in thus creating positive pressure and keeping dust out but maybe trapping to much hot air in the case
    2/ Having the rear 360 and the bottom 2 fans blowing in and the top thinner 360 exhausting
    3/ Just have the one 360 rad at the rear front blowing in along with the 2 or 3 fans at the bottom and have 3 fans at the top exhausting ( depends on the pump/reservoir if its 2 or 3 fans at bottom )
    Want to get this build right and dont want to say a couple of weeks down the track I should have done this. Havent ordered nothing but in the case currently I have 6 noctua 120mm fans .
  2. mojododo
    mojododo Member
    Feb 14, 2004
    3,402
    Looking at the case id blow both rads out and fresh air via bottom fans
  3. danielvh
    danielvh Member
    Dec 22, 2002
    1,083
    This.
  4. emmjawsX
    emmjawsX Member
    Oct 14, 2016
    42
    Hardware Canucks did a video on 9 fan setup, using an AIO for the cpu and an air cooled gpu.
    Full loop would obviously be a bit different but i think the takeway is with that many fans config doesn't matter a whole lot :leet:
    Depending on the radiators you pick it can be a tight fit installing in the top/side. The xspc slim i have in the side was very tight around the ports, i probably should've filed around it a little but just managed to get it to fit. Recently upgraded to a thick SR2 in the top and it barely fit as well.
    Will S
    Will S Member
    Aug 15, 2003
    5,258
    thats how I have the case setup now...aio top exhasut , 3 at bottom and 3 at side....and yes, will the rads fit...the Hydro Config has one on bottom and one on top
    or maybe a 240 at the side intake so only have 8 fans
    edit: well just took the case apart and I think a thin 360 sitting behind the back ( side ) with 3 fans blowing in next to the vent on the side panel , that way could have a thick rad on the top exhausting and still have 3 fans on the bottom of the case sucking in
    or maybe just 2 Corsair XR5's
