Alessandro MS1i Re-cable
Discussion in 'PC Audio' started by FlyN, Oct 24, 2010.
  1. FlyN
    FlyN Member
    Sep 8, 2005
    184
    So, my MS1's finally arrived :D
    They sound awesome - especially coming from Yuin PK3's and previously Sennheiser HD215's.
    However, given my hatred of "Y" cables it didn't take long for me to get sick of the standard cable.
    So here is my ~$5 re-cable:
    I ended up deciding to feed the cable connecting right driver to left through the headband - a real PITA to get a flexible wire through:
    Opening up the drivers without causing damage isn't easy. I opted to break the glue loose with a thin screwdriver - caused some very minor damage to the casing but it's hidden by the ear pads etc.. Turns out they are just held together with hot melt glue.
    I connected the main cable to the left driver and fed the right channel through the headband (sorry, bad pic):
    Both drivers were soldered to there respective wires and closed up by tacking them at a few places with epoxy.
    The end result; Max of 30mins of work (1.5m cable length):
  2. dazzawul
    dazzawul Member
    Apr 29, 2005
    1,459
    the sutho shire (w00t)
    Nice work man!
    FlyN
    FlyN Member
    Sep 8, 2005
    184
    Thanks,
    They look different now, I didn't like the long cables on the ear cups:
