AMD HTPC Motherboard help
Discussion in 'HTPC' started by kyok11, Aug 3, 2009.
  1. kyok11
    kyok11 (Banned or Deleted)
    Feb 24, 2006
    114
    NSW
    I hope this is the right place to ask this. Please move it if not. Cheers
    I am looking at building a AMD based HTPC and not sure which motherboard to go with. I will be using parts left over from my old rigg. Will be putting them into a Silverstone LC13-E case so I can use an ATX board. Have been looking at the Gigabyte GA-MA78G-UD3H. My requirements is for the board to have HDMI and onboard graphics, though will be changing to a better GPU later on.
    Please let me know if you have had any experience with the GA-MA78G-DS3H, or if you recommend something else.
    Parts being reused:
    CPU: 5600+
    Ram: 4gig Team Xtreem Dark 1066
    HDD: WD 250gb & WD 1Tb
    DVB-T: Digital Now Dual
    PSU- SuperFlower 800w
  2. Apokalipse
    Apokalipse Member
    May 29, 2006
    4,250
    kyok11
    Feb 24, 2006
    114
    NSW
    Thank you Apokalipse
  4. Mr Bubbles
    Mr Bubbles Member
    340
    Brisbane City
    These boards seem to be cheaper than the 790GX HD3300 boards. Is that because they don't have sideport memory? I realise the new HD4200 has a few improvements wrt video playback but do these new HD4200 chips do better or worse for gaming? Any HD4200 boards in the pipline have sideport memory?
  5. Oppressa
    Oppressa Member
    Jun 5, 2004
    5,573
    I've also been interested to see some comparisons between 780/90 and 785.
    Found this:
    http://www.tomshardware.com/reviews/amd-785g-chipset,2381.html
    Looking at the graphs here, the 785 was in fact slower for some of the tests :|
    http://www.tomshardware.com/reviews/amd-785g-chipset,2381-10.html
    Slightly better HD performance in the 785
    http://www.tomshardware.com/reviews/amd-785g-chipset,2381-13.html
    Their conclusion:
  6. Maldark
    Maldark Member
    Jul 19, 2004
    666
    Newcastle, NSW
    Gigabyte GA-MA785GPM-UD2H
    The P in the name indicated sideport.
  7. viggenn
    viggenn Member
    Mar 6, 2008
    439
  8. Apokalipse
    Apokalipse Member
    May 29, 2006
    4,250
    the Radeon 3200 IGP (780G) is better than the 8100
  9. Mr Bubbles
    Mr Bubbles Member
    340
    Brisbane City
    795gx will be here in a few weeks
  10. General_Cartman
    General_Cartman Member
    Apr 28, 2005
    2,749
    The Confedaracah!
    If you are going to add a seperate GPU later, I'd suggest getting an Nvidia chipset. Because, when you get the external GPU you can use the Hybrid Power feature of the chipset, which powers down the external GPU when it's not being used, allowing you to save power and lower system noise. AMD have a similar feature on their laptop chipsets, but not the desktop ones, for reasons only known to them.
  11. Mr Bubbles
    Mr Bubbles Member
    340
    Brisbane City
    I thought hybrid power doesn't work with the newer Nvidia cards. Or did I miss something?
  12. dobbyb
    dobbyb Member
    Mar 10, 2009
    163
    Geraldton
    Yeah I'm pretty sure nVidia have quietly canned hybrid power.
  13. Mr Bubbles
    Mr Bubbles Member
    340
    Brisbane City
