AMD Radeon R7, R9 2xx GPUs 28nm | 250 260X 270X 280X 290X | Discussion
Discussion in 'Video Cards & Monitors' started by vid_ghost, Jan 10, 2012.
  1. Frag
    Frag Member
    Feb 22, 2002
    5,201
    Brisvegas
    Doh, forgot you have 290 not X. Oh well I will work it out when I get them under water. Weird, I'll hunt XS forums to see what is going on.
  2. bobster
    bobster Member
    Nov 11, 2011
    1,027
    This is my 290 at stock volt oc to 1050mhz gpu and 1400mhz ram. Gpu goes up to 1085 without artifacts on stock volts and not pushed the ram anymore yet.
  3. Beaner
    Beaner Member
    Dec 30, 2001
    737
    My new R290X has terrible coil whine when loading up WoW. Anyone experienced that?
    Wow: Just searched through the thread. This is terrible lol. Another card getting RMA'd I think
  4. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,963
    St Clair 2759
    Yeah pretty high RMA rate on these, about to send my second one away.
    :thumbdn:
  5. kEv_
    kEv_ Member
    May 5, 2012
    565
    did you get your voltage adjustment? i just downloaded from guru3d and it's good to go, but i'm unsure if i want it as it seems to make the card run worse:confused:
    having the extra voltage stopped my artifacting but seems to have done something weird to my scores, any ideas anyone?
    here's a comparison of my best run, with a small amount of artifacts, with this latest run
    http://www.3dmark.com/compare/3dm11/7505817/3dm11/7475307
  6. Beaner
    Beaner Member
    Dec 30, 2001
    737
    Yeah. I bought from ITESTATE hope that process goes OK.
  7. Beaner
    Beaner Member
    Dec 30, 2001
    737
    Hey all:
    For those that have RMA'd due to Coil whine, did it resolve the issue? Or is it something that my PSU may be causing ? (Seasonic Platinum V2 860w) What a frustrating problem.
  8. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    I have the same psu and no whine.
  9. mAJORD
    mAJORD Member
    Jun 4, 2002
    12,622
    Griffin , Brisbane
    M12 II 850 . No audible noise.
  10. Geno
    Geno Member
    Sep 23, 2003
    2,116
    Neither of my XFX 290's make a peep with regards to coil whine.
  11. Ogre
    Ogre Member
    Aug 13, 2003
    2,454
    Sydney, Australia
    Pretty sure the coil whine is a hardware 'fault'
  12. Beaner
    Beaner Member
    Dec 30, 2001
    737
    OK thanks all. I'll let you know my results post RMA.
  13. sw-m78
    sw-m78 Member
    Oct 7, 2003
    292
    Brisbane City
  14. Twizzly
    Twizzly Member
    Oct 29, 2008
    711
  15. master phi
    master phi Member
    Nov 1, 2004
    1,403
    I can hear Tom Jones right now.
  16. Muddy Funster
    Muddy Funster Member
    Apr 13, 2012
    661
    QLD 4455
    P22895
    looks like I am stuck at 1150/6000 at this stage with stock coolers, artifacts otherwise
    Graphics Score 31957
    Physics Score 13721
    Combined Score 10780
  17. Scarecow
    Scarecow Member
    Nov 2, 2013
    292
    I had to RMA a gigabtye card and I'll be doing the same with a ASUS 290x too, both cards have coil whine and its not my system causing it as I have tested with other systems and the whine in all of them :thumbdn:
  18. master.Cuong
    master.Cuong Member
    Feb 20, 2007
    482
    I did have a gigabyte 290 which had coil whine and returned the card and upgraded to 290x so now no coil whine. Both are gigabyte
  19. sjp770
    sjp770 Member
    Apr 23, 2009
    1,723
    Sticks, NSW
    Try at a lower MEM OC. I could push higher and be more stable if the ram wasn't up at 6000
  20. TaroT
    TaroT Member
    Jan 18, 2002
    8,727
    Hazelbrook nsw 2779
    ok has anyone actually narrowed down excatly *where* the coil noise is coming from...since these don't really have *coils* the vibrate...what is.
    can't really be the cooler as it happens on aftermarket /water and stock.
    ayone with a smaller waterblock able to locate it?
    i have not got it on mine(the saphire) but in the end did have it a little on the gigabyte...nowhere near as bad as the worse ones though.
    also i experienced black screen...pain in the ass.
    comes down to trying to setup profiles in afterburner...i was setting up a nice stock one but slid the power slider into the negative and boom black screen.
    so definitely could be power related(wether or not it is a fault in the card or the software who knows
