AMD socket watercooling compatibility help
Discussion in 'AMD x86 CPUs and chipsets' started by choppa, Nov 9, 2018.
  1. choppa
    choppa Member
    Jan 1, 2002
    2,501
    Asia-Pacific
    Hi,
    I have a dual Socket C32 based motherboard (a Supermicro H8DCL-iF); from what I've read online, the C32 socket is similar to Socket AM3 - but I can't find a layout online to confirm.
    I'm trying to figure out if the Corsair H80i V2 will work on my motherboard basically before I go out and buy it. Appreciate any help anyone can offer.
    Thanks.
  2. Sgt Bilko
    Sgt Bilko Member
    Mar 5, 2015
    1,118
    Canberra(ish)
    I've not personally used any C32 system but the mounting is more akin to Socket 939/754 than AM3
    After a google around it seems nearly any cooler that latches onto the brackets (if you have them) will work just fine
  3. philquad
    philquad Member
    Jan 22, 2004
    1,410
    nelson bay
    looks amd by the latches
    but, normally the amd brackets have 4 screw holes, this has 2, so wont the H80i need the under bracket to screw to ?
    choppa
    choppa Member
    Jan 1, 2002
    2,501
    Asia-Pacific
    I've been looking at a heap of pictures online and it seems the 2 screws on either side from the CPU centre are at the same distance as for those on the AM3 socket.
    I guess I'll just have to buy a WC cooling kit that has brackets for all AM1/2/3/4 CPUs and try it out, as the documentation seems quite sparse.
  5. philquad
    philquad Member
    Jan 22, 2004
    1,410
    nelson bay
    choppa
    choppa Member
    Jan 1, 2002
    2,501
    Asia-Pacific
    philquad - you're not mad, but correct, only 2 mounting holes
  7. philquad
    philquad Member
    Jan 22, 2004
    1,410
    nelson bay
    maybe you could mod the top bracket to fit just 2 holes
    use a fbh
  8. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,286
