Amplifier Selection - Help me narrow my choices
Discussion in 'Musicians' started by break, Sep 24, 2009.
  1. OP
    break
    break Member
    May 31, 2003
    7,332
    Pub gigs, typically its 50/50 as to being mic'd up or not, so I need the flexibility of both.
    I don't care about wall shaking at home (to a degree, so long as I don't have to wear ear plugs to play it at home I'm happy)
    I don't care about the weight either.
  2. Liam.
    Liam. Member
    Jul 23, 2006
    859
    a marshall dsl50 and a cab went on ebay a couple of months ago for around 1200.... jcm900 @ melb gumtree http://melbourne.gumtree.com.au/c-S...00-SLX-High-Gain-100W-Head-W0QQAdIdZ146280259 $800, a courier to get it delivered around $40 with insurance. then you just need to find a cab. there's so many good deals when you buy 2nd hand... sure go try some amps new at a store but the fact is you aren't getting all that much for that price range compared to 2nd hand.
