Android tv
Discussion in 'Audio Visual' started by aza2001, Feb 16, 2016.
  1. aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    Hi All,
    before I take the plunge, i would like to ask a few questions out there regarding android tvs and hopefully it doesn't have any limitations ...
    I want to find out if I can run apps like tasker, and openvpn on the unit?
    any other limitations as to what android apps it can't run/ shouldn't be run?
    Cheers,
    Az
  2. ni9ht_5ta1k3r
    ni9ht_5ta1k3r Member
    Feb 11, 2006
    35,075
    地球・オーストラリア・シドニー
    the nvidia shield tv looks sweet!
    aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    lol... this does not answer any of my questions... my questions about apps not what devices lol
  4. ni9ht_5ta1k3r
    Feb 11, 2006
    35,075
    地球・オーストラリア・シドニー
    it should just work like any generic android device....but if you root the device you might increase your chances.
    aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    thanks mate for the headsup :)
  6. Draebor
    Draebor Member
    950
    Gold Coast
    ive recently bought a sony 4k android tv.
    seems good so far, and you can enable developer options to sideload applications from usb media, which ive used to install a kodi release candidate.
    application wise, the appstore is limited to apps which are tv ready - im not sure tasker and openvpn interfaces would be suitable for tv use. that being said i have a mouse plugged in (logitech couch mouse) to one of the usb ports and that works fine in all my apps. apparently you can install a 3rd party launcher and use non-tv native applications sideloaded onto the tv. i have yet to test this, i want to get the gmail client and calendar on my tv also so will be having a play with this on the weekend.
    aza2001
    aza2001 Member
    Sep 14, 2002
    2,016
    Northmead
    I found a reddit thread where someone put tasker on the unit, but required it to be rooted to restore a backup from titanium backup.
    looking to throw emby/ plex on the unit or use kodi with a bunch of addons
  8. Draebor
    Draebor Member
    950
    Gold Coast
    plex and kodi are on google play, so easily available :)
    dont think i would root my tv personally, wouldnt that void the warranty?
