Another DIY headphone stand!
Discussion in 'PC Audio' started by Defyant, Mar 15, 2015.
  1. Defyant
    Defyant Member
    Mar 11, 2004
    1,357
    Defyant Modded "Tail" Lights!
    This is my stand :) built for 2 headsets with a winged keel theme to it.
    I wanted some thing with a hot swap jack and a light as i do a bit of late night music listening and gaming.
    All made from scraps with a few bits from jaycar powered from usb.
    bit of a work log
    The base is a scrap piece used as it just edged for looks and the middle is the same for the center clear piece.
    a bit of dremel work is done to insert the earphone jack which is connected to a 3mtr diy ext cable to the pc out.
    ive used to cat5 cable for the ext.
    A 5mm blue cree is wired to a resistor to knoclk off 2 v and sent wired to a usb male plug.
    This gives me a jack i can use to swap between my gaming cans and music can that's lit for late nights.
    Using cat5 gives me plenty of wires for power and audio.
    The cat5 is sleeved with connectors added and heat shrinked.
    Rubber feet added
    Weldon perspex glue is used to hold it all together recently adding a screw each shit to help.
    Cheers
  2. mitsimonsta
    mitsimonsta Member
    Aug 21, 2006
    10,994
    2161 / 2060
    Awesome work mate, love the design.
  3. Renza
    Renza Member
    Dec 1, 2004
    4,664
    No shielding on the audio lines?
  4. Quelch
    Quelch Member
    Mar 25, 2007
    684
    You're an artist
    Clever design and execution
  5. Houston
    Houston Member
    May 31, 2007
    62
    In a house
    looks great, a coat of paint would top it off
