Any experiences with Better Batt batteries?
Discussion in 'Photography & Video' started by synoptica, Oct 21, 2013.
  1. synoptica
    synoptica Member
    May 26, 2002
    2,381
    St Kilda East, Vic
    Hey all,
    My newly acquired 50D's battery leaves a lot to be desired, in start contrast to my outgoing 450D which would see weeks of use without a recharge.
    I've done a bit of shopping around, and have come across Better Batt (http://www.camera-battery.com.au/) who seem to have some decent guarantees and reasonable prices, and a few good reviews too.
    So while it all looks promising, batteries are normally an area of the aftermarket I tend to avoid, but the pricing on a genuine Canon item is beyond excessive.
    Has anyone used any of their items - if so, what was your experience?
    Also - if anybody local is thinking of placing an order, let me know if you want to combine postage! $10 for a single item seems excessive, but free for two or more!
  2. RichoB
    RichoB Member
    Sep 29, 2005
    540
    I bought a couple of batteries for my Fuji and performance seems to be on par with the first party battery. They've probably been through ten or so cycles.
    I'd recommend them.
    synoptica
    synoptica Member
    May 26, 2002
    2,381
    St Kilda East, Vic
    Thanks for the advice! Seems most feedback for them is quite positive. Their cheap-looking website throws me off a bit!
  4. Zee
    Zee Member
    Oct 27, 2002
    12,100
    SYD/MNL/SIN/SFO
    I'd look at Sterlingtek, I have found their Canon batteries to be 20%-30% longer lasting than the Canon originals, and way cheaper. I am also talking long term, not just the first few charges.
    Z...
    synoptica
    synoptica Member
    May 26, 2002
    2,381
    St Kilda East, Vic
    They do look good, but no Oz shipping option it seems :(
  6. Audionut
    Audionut Member
    Mar 7, 2006
    1,540
    4610
    Got a few batteries off these guys for a 5D3. They work, unlike other cheaper branded batteries in the 5D3. Nothing scientific but they feel like they last at least as long as the Canon branded ones.
    http://stores.ebay.com.au/dstepower
  7. Zee
    Zee Member
    Oct 27, 2002
    12,100
    SYD/MNL/SIN/SFO
    If you can wait, I'll be in the US in about a week.
    Z...
    synoptica
    synoptica Member
    May 26, 2002
    2,381
    St Kilda East, Vic
    I can very much wait :) My lens is in for a service anyway.
    Of course, only if it's no trouble though!
  9. glenpinn
    glenpinn Member
    Dec 11, 2006
    6,780
    this is the best battery supplier i have ever used by a mile, and in over 10 years all their batteries have been brilliant, service is great, and prices are pretty dam good.
    http://aubattery.net/panasonic/vbg260.html
    a 1050mAh battery for my cameras from Better Batt is $27.11 where i can get a 2850mAh battery from aubattery.net for $29.99, and my 5800mAh batteries are $49.99 each.
  10. StuartL
    StuartL Member
    Nov 6, 2007
    1,094
    Melbourne, Australia
    Just be careful - I've had experience with el cheapo third party batteries that worked great at first, but couldn't hold a charge after a few cycles. Don't judge them at the start of their life; judge them by what they're like after 6-12 months (granted, difficult to do unless you run a review site, or can find a good review of them...)
  11. glenpinn
    glenpinn Member
    Dec 11, 2006
    6,780
    batteries are no different than any other item you will buy, some just dont cut it, just like you will get the odd faulty hdd or laptop or whatever, sometimes batteries are the same.
    dont be fooled into thinking that a canon battery is any better than an oem battery made on mass in a factory in china, because in most cases, the manufacturers battery is no different.
    i have bought hundreds of camera batteries since 1999 and never had any of them fail on me even after a couple of years use, and most of them i bought from http://aubattery.net/panasonic/vbg260.html
    i also buy lots of laptop chargers and batteries from a reputable supplier in ebay, all shipped in from hong kong, all over 50% cheaper than the exact same ones sold by the manufacturer, all the same product, just that the manufacturer sticks their own label on them.
    that Better Batt store buys their batteries from the same oem factory as everyone else, and just puts their own sticker on them, just like all the others do.
    pricing is about the only difference between all these batteries, one store will be cheaper than others.
  12. Zee
    Zee Member
    Oct 27, 2002
    12,100
    SYD/MNL/SIN/SFO
    If you order it, and get it posted to a US address I give you, it'll be no hassle.
    Z...
  13. Audionut
    Audionut Member
    Mar 7, 2006
    1,540
    4610
    I go through a set of batteries in the grip every 5 days or so and rotate the dtsepower ones with Canon ones. Been doing this for 6 months or so with no problems. Some other cheap piece of shit ones I got won't boot the camera when they're under 30% charge :shock:
    Good advice anyway though :thumbup:
  14. sml_nail
    sml_nail Member
    Jul 29, 2002
    1,027
    Newcastle, NSW
    Resurrecting an old thread but care to share said ebay seller. I'm looking to purchase a couple of batteries and have been stung in the past.
  15. Squeezer
    Squeezer Member
    Feb 25, 2002
    6,869
    I bought aftermarket batteries for Sony A7R from betterbatt as well as some Sony N970 bricks and they seem to hold charge well. Substantially cheaper than Original
  16. lonewolf1983
    lonewolf1983 Member
    Jun 12, 2002
    5,060
    Perth, WA
    i have a couple (d3, d4, a99 and a7 styles)
    All have held up well, and yes huge price savings.
    Went with them as they're in AU so any warranty claims are far easier, as opposed to an ebay seller from HK etc
    synoptica
    synoptica Member
    May 26, 2002
    2,381
    St Kilda East, Vic
    Holy shit, this was three years ago??
    In any case, the batteries have stood the test of time; would happily recommend BetterBatt to anyone!
