Apple agrees to battery replacements for 6S
Discussion in 'Apple iOS (OS & Devices)' started by MoNk{LAH}, Nov 26, 2016.
  1. MoNk{LAH}
    MoNk{LAH} Member
    19,973
    https://www.apple.com/au/support/iphone6s-unexpectedshutdown/
    Apple has determined that a very small number of iPhone 6s devices may unexpectedly shut down. This is not a safety issue and only affects devices within a limited serial number range that were manufactured between September and October 2015.
    If you have experienced this issue, please visit an Apple Retail Store or an Apple Authorized Service Provider and have your device's serial number checked to confirm eligibility for a battery replacement, free of charge.
    I;ve had my 6S shutdown at 57%, 40% and 10% in the last 2 days. I hope i can get a replacement battery (2nd hand 6S off ebay)
  2. pittster
    pittster Member
    Mar 25, 2011
    1,000
    Newcastle
    I got mine replaced last week, didn't know about this defect but same thing always dying at around 50-40%
    MoNk{LAH}
    MoNk{LAH} Member
    19,973
    Did you get a brand new phone on the spot? Or just replace the battery in your old phone?
    and how long did it take to replace (assuming they had stock at the time)?
    need to bring anything in to confirm you were the owner?
  4. pittster
    pittster Member
    Mar 25, 2011
    1,000
    Newcastle
    Nope just brought phone in swapped for a new one ( the phone you get is a repaired phone from another warranty but thats normal) standard Genius Bar replacement.
    MoNk{LAH}
    MoNk{LAH} Member
    19,973
    went to an apple store, they didnt have stock, and batteries will be in 10-15days.
    Fine with me, i got my old phone back anyway
  6. wullieb1
    wullieb1 Member
    Jul 9, 2013
    457
    Mine shuts down at around 30%. Plug it in for a few secs and it comes good and will last for the rest of the day. Has happened a few times now.
    Reckon this will cover that?
  7. wwwww
    wwwww Member
    Aug 22, 2005
    5,317
    Of course, even if they don't you're covered by the stat warranty.
  8. wullieb1
    wullieb1 Member
    Jul 9, 2013
    457
    I'll go in tomorrow then as we got the phone in Oct last year so in the right time frame for it to be a possible issue.
    MoNk{LAH}
    MoNk{LAH} Member
    19,973
    You should be covered, so long as it's within their batch of affected phones - they will check your serial number.
    I read on WP, from REddit:
    No idea if it's confirmed, but mine is a Q9
