Arcade MAME cocktail cabinet ........56k nope..
Discussion in 'Retro & Arcade Worklogs' started by meth05, Jul 16, 2008.
  1. meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Thought I would post my ongoing mame cocktail cabinet build that i have been working on for a few weekends.
    Not having that much woodworking experience has shown in the build quality lol but its been fun so far :)
    So to start i borrowed the legs off an old tray thing
    Hosted by UGBox Image Store
    Purchased some 12mm MDF from good old bunnings, chop chop!
    Bogging up the shoddy workmanship ready for sanding
    Some primer ready for another big sand
    The Legs had a few extra holes from when it was the stand, so a little more bogging
    Little nip at the fingers :)
    The work bench i built a couple weeks b4
    The holes on the legs filled & mounted
    Some items sitting inside
    I picked up a few items from Jaycar.
    - 3" Speaker Grills
    - Pocket Handles
    another view
    Hopefully Ordering all my controls tomorrow from OzStick so stay tuned
    Cheers.
  2. elvis
    elvis Old school old fool
    41,394
    Very innovative. I like. :thumbup:
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Starting spray up using just a flat black.
    Came up ok, still a few spots to fix.
    Ctrl box almost finshed
  4. BlackTigerTech
    BlackTigerTech (Banned or Deleted)
    Jan 27, 2008
    61
    2040 Sydney
    Woah...very nice work there...waiting for more updates tho!:thumbup:
  5. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    Looking forward to updates:thumbup:
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Just sitting the Ctrl box on a stool to have a look & thats dust on the lens btw
  7. AussieJester
    AussieJester Member
    Jul 12, 2004
    2,552
    Perth Western Australia
    Nice work mate and nice touch adding a pic of you doing the job too imo not enough put a pic of the "mug" in there... top job ;-) Look forward to more updates best of luck...
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Spent a couple hours last night working on mounting the screen "not the most fun job" pics coming.
    Waiting on OzStick to get my Controls to me. I wanted it finished this weekend for a mate’s party but that’s looking doubtful.
    edit....just found out my Ctrls wont be here in time..:(
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Lunch break day off update
    First couple of pics are from thr other night.
    **if you don't have experience working on de-cased crts please read up on the dangers!!
    I was finding it hard working out the screen placement so i cut a template to help.
    Dads little helper
    Initial cutting done, lots of trimming and filing left to go
    Mounting supports
    Fitted and ready to roll
    I knew i would have VERY little clearance went putting this CRT in
    So i added some rubber standoff to add a couple mm
    Not easy putting the top on by myself but i got it done
    well back to it:)
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    My Controls arrive today! so its a long night in the cold shed tonight :)
    Up close with a couple credit buttons and power all red led
    Holes cut out ready for fitting
    Buttons in place, had to pull the white joystick apart to tighten the throw on it.
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
  12. TERRA Operative
    TERRA Operative Member
    Jul 8, 2005
    6,925
    Niraikanai
    Any reason you didn't mount the joysticks from behind? You'll be able to hide the metal flanges if you do that.
    Nice work so far. I wouldn't mind a cocktail cab, once the 3 other cabinets we have are finally finished...
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    I'm putting a overlay on the control box so you won't see the flanges also the shaft length on these particular joystick was really small when mounted on the underside through 12mm. :thumbup:
  14. TERRA Operative
    Jul 8, 2005
    6,925
    Niraikanai
    Ah ha. Makes perfect sense then.
    The ones we used had longish shafts, so we could mount them from behind.
  15. elvis
    41,394
    Those sticks are made by Sanwa. They're really designed for metal/plastic control panels up to about 6mm in depth max.
    Flush-mounting them on top of the panel with a routed recess and then whacking an overlay of some description over the top is definitely the best option if you have a wooden CP. Rear-mounting these sticks makes them way too short for decent play.
    meth05
    meth05 Member
    Apr 11, 2005
    556
    BENDIGO
    Things left to-do:
    Done - Finalize screen mount & test
    Done - Mount Power Supply & Motherboard HD
    Done - Cut holes for speakers & mount 3" speaker grills
    Done - 2 80mm LED fans on sides
    Done - Attach Feet
    Done - Finish Crtls
    Done - Overlay Ctrl box
    Done - Mount Ctrl Box to main body
    Done - Spray Top
    Done - Touch up scratches/chips
    Done - Cut hole for power cord & mount grommet.
    Done - Cut hole for ctrl cable back to PC
    Done - Purchase glass, Fit.
    Done - Cut and Fit Credit buttons
    Done - Cable management inside
    Done - Purchase power board & Fit
    - Add quick disconnects to 12v line for the credit and power button
    - Wire all powered buttons
    - Cut and fit externally accessible usb plugs
    - Purchase Red Caroma Stool off eBay
  17. Deadshot_80
    Deadshot_80 Member
    Mar 11, 2007
    868
    Melbourne East
    that's cool wish i had the time to make one :thumbup:
  18. FuzzyKaos
    FuzzyKaos Member
    2,169
    I dont understand why you use ye old crappy crt, whats wrong with an LCD?
    mame on my plasma tv looks flawless.. mame on my xbox looks flawless..
  19. r3flexion
    r3flexion Member
    Dec 21, 2003
    223
    because "crappy" old CRTs have a better viewing angle than LCDs and plasmas. You wouldn't be able to use an LCD or plasma for this project. Also, CRT has the retro vibe.
  20. captainpotato
    captainpotato Member
    May 31, 2003
    345
    Not to mention that the vast majority of the arcade era games run at different resolutions and refresh rates. Even a standard CRT PC monitor doesn't manage it as well as a dedicated screen that can do them.
    Having said this, from what I gather, vector games work well on higher resolution plasma and LCD screens, because they can get closer to the original vector monitor look.
