Arduino beginner
Discussion in 'Electronics & Electrics' started by Agg, Jan 7, 2017.
  1. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,633
    Broadview SA
    You're on the right track, although the actual code you've posted is riddled with errors. Start here: https://www.arduino.cc/en/Reference/ServoWrite
    Code:
    #include <Servo.h>
    Servo ServoLft;
    Servo ServoRgt;
    void setup()
      ServoLft.attach(9); // Left motor on  pin 9
      ServoRgt.attach(10); // Right motor on pin 10
      // Make the robot go forward at full speed
      ServoLft.Write(180); // An "angle" of 180 degrees will set a continuous servo to full speed
      ServoRgt.Write(180);
      // Continue for 1 second
      delay(1000);
       // Make the robot stop
      ServoLft.Write(90); // An "angle" of 90 degrees will set a continuous servo to stop
      ServoRgt.Write(90);
      // Wait for 1 second
      delay(1000);
      // Drive the left wheel forward and the right wheel in reverse to make a sharp right turn
      ServoRgt.Write(0);
       // Continue for half a second
      delay(500);
      ServoLft.Write(90);
      ServoRgt.Write(90);
    void loop() {}
    Note that with a continous servo you have no positional feedback, so there is no way to specify that the shaft should turn through a precise angle, and thus no way to make a 90 degree turn other than empirically determining how long the motors should be driven to do so.
  2. MUTMAN
    MUTMAN Member
    9,392
    4109
    Wont a stepper motor be a better option at that time ?
    or a regular DC motor and a H bridge driver ?
  3. Madengineer
    Madengineer Member
    May 27, 2011
    14,481
    Well I don't know? I've asked about it, but nobody has given me suggestions. It's my first real step into it. I've tried with stepper motors, and I mustn't have coded it right, or it was too much stress or something, but they're not working now (and I haven't been able to get them to work ever since).
    A servo motor isn't exactly the best. But I had it available.
    Do you think a regular DC motor and h bridge driver would be better? (I have no idea what a H bridge driver is but I'm googling it right now)
    Pretty sure I've got a H Bridge Driver at home (I bought a large kit of gear).
    Would this DC motor be usable?
    Wrong link
    https://www.ebay.com.au/itm/DC-12V-...hash=item4b1bb34b36:m:moCGDsFRaBJC_jtdjaGTUjQ
  4. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,633
    Broadview SA
    A servo motor is just a DC motor with an angle sensor, an error-proportional control circuit, and an H-bridge built in. A continuous-rotation servo is the same thing but with the angle sensor defeated such that it always reads 90 degrees - input angles less than 90 degrees will drive the motor one way, angles greater than 90 degrees will drive it the other way, with speed proportional to the difference from 90 degrees.
    So yeah. Same thing, just wrapped up in a somewhat handy package.
    But for wheeled robotics work a stepper motor (or some kind of encoder-feedback system) is much better, so you can dead-reckon approximate position and orientation from the rotation of the wheels and their circumference.
  5. Madengineer
    Madengineer Member
    May 27, 2011
    14,481
    So I should just use a stepper motor?
  6. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,633
    Broadview SA
    Depends what you're trying to build! If you don't actually need to know your position or orientation (for instance, a line-follower robot) it doesn't matter, and servos are a lot cheaper.
  7. Madengineer
    Madengineer Member
    May 27, 2011
    14,481
    Basically I'm automating a lego model (pneumatic excavator).
  8. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,633
    Broadview SA
    Automate in what sense? Are you motorising for remote control? Motorising a few parts for a mostly-static display? Building a fully autonomous vehicle to very slowly empty your sandpit? You can't pick an appropriate solution until you define your requirements.
  9. Madengineer
    Madengineer Member
    May 27, 2011
    14,481
    Basically I want to eventually setup motors to make it go forward and turn (when detected input from a knob of some sort) as well as other various motors to control functions of the excavator.
  10. oculi
    oculi Member
    Aug 18, 2004
    11,794
    why don't you just use lego motors then? H bridges are cheap as chips on ebay etc.
  11. MUTMAN
    MUTMAN Member
    9,392
    4109
    sounds like position feedback is required for at least some functions
    you need a mix of servo and dc motors on h bridges
    for the h bridge look for l298n on google
    edit its a l298n not a ln298
  12. desertstalker
    desertstalker Member
    Feb 5, 2005
    386
    Servos generally go to a certain position then stop, few of them are capable of 360deg rotation ( I have never used one). perhaps link to the device you are trying to control?
  13. Madengineer
    Madengineer Member
    May 27, 2011
    14,481
    Cause it's not as fun? :D
  14. PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,571
    Pretty sure the answer will be no, but is there any way of getting code back of an Arduino?... I put down my Xmas lights project a while back because I got distracted by something else shiny... It's Xmas now, and the boss wants lights... who am I to argue.
    However, I don't remember what was loaded onto the Arduino, or what pins to hook where, nor do I recall the last thing that was uploaded to it... so I'd like something like a 'show running-config' on a Cisco switch so I can see where I need to hook my inputs and outputs up to.
  15. pantner
    pantner Member
    Aug 31, 2004
    2,248
    Perth, WA
    Not that i am aware of. The way i understand it, the code you input into the Arduino IDE is compiled before it is uploaded. Even if you could get it off you wouldn't be able to read it.
    I know it doesn't help now but, suggestion for future projectors, put the pin config into some serial prints at the start of the program defining the pins used, etc.
    What did the program actually do/how complicated was it? was it just a timing program that turned a FET/Relay on/off to make lights flash? or more complicated than that?
  16. PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,571
    Just spat out a bunch of stuff for the WS2812b LED's I'm using, using the FastLED library from memory.
    I just poked around with a jumper between the board and the LED strings, and found which pin I was outputting to, so it's all good. Now I can go back through all my old project files and find the one that seems to do the same thing :).
  17. desertstalker
    Feb 5, 2005
    386
    Might want to put some sort of identifier (output to console or whatever they call the USB serial interface) on program start so you can tell what is programmed onto the arduino for next time.
  18. MUTMAN
    MUTMAN Member
    9,392
    4109
    Same idea ? Either way thats a handy tip for those of us that have only sporadic times with our toys
  19. PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,571
    So I'm still futzing around with my lights.
    FastLED is magical, and lets me run 4x100LED strings defined as an array, off 4 Digital Outputs on my Arduino.
    In Physical terms, there's a horizontal power cable strung along the top, tapped into for each vertical run of lights, also, for the signal wire, I've used some old Cat5 cable I had lying around, each string of lights is one pair, and I've tapped the sheath and fished out the required pair at each joint.
    I've done some continuity testing on each of the pairs and don't have any shorts, but something is not right.
    With no signal pin connected, a Strand of WS2812's shouldn't really be doing anything (I think it stays in whatever state it was at the end)... however, I can unplug 3 of the 4 signal wires from my Arduino, and still have all 4 strands displaying the demo.... I'm trying to work out where these phantom signals are coming from.
    Any ideas?
  20. MUTMAN
    MUTMAN Member
    9,392
    4109
    crosstalk on the ethernet cable ?
