Assistance with optical audio output on 4K TV
Discussion in 'Audio Visual' started by roweysvn, Sep 25, 2016.
  1. roweysvn
    roweysvn Member
    Dec 22, 2005
    455
    Gold Coast / Brisbane
    Hey Team
    I was recently gifted a new 4K TV, it's fairly low end, but after having a quick look at it, I was under the assumption it should work with my Logitech (don't judge me!) 5.1 surround unit. But after connecting everything I can't get the audio to work.
    The TV in question is a Kogan KALED55UHDZF Prior to this I was using a Sony 40" TV connected to a Logitech Z5500 5.1 speaker setup via Toslink Optical Audio Cable. The speakers were working fine prior to unplugging from the Sony, so I know it's not that, it just reads as 'No Optical Input" on the Logitech panel
    * In the TV manual, it shows the following image for connecting via optical - http://i.imgur.com/QgIlY27.jpg
    * The TV has the following jackpoint on the side which corresponds to the diagram (Note: The black jack is for heaphones not optical) - http://i.imgur.com/CAnG56I.jpg
    * This is the back of the Logitech control unit, I have been connecting from the Digital Toslink jack, to the yellow jack on the tv in the previos image - http://i.imgur.com/Qi7jLzI.jpg
    * The cable I'm using is reversible, you can have one end toslink, and the other looks like it's a 3.5mm jack but with a small opening at the end - http://i.imgur.com/5ddyDff.jpg & http://i.imgur.com/tQJ80Qt.jpg
    I'm hoping someone can shed some light on what I'm doing wrong here, the manual seems to indicate I need to run coax as well as a second CVBS cable, then into some kind of adapter, which I am unfamilar with. But looking at the Logitech control panel, I'm not sure this is going to work.
    Is my speaker unit no longer compatible with my tv? Could there be another alternative to get things working?
    Any advice would be appreciated!
  2. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    994
    Central Coast
    That socket on the tv serves dual purposes:
    1. digital audio out, and
    2: Composite video output.
    So you dont need to run a second cvbs (aka composite) cable. Your tv might have come with a y splitter/adaptor that is meant to be used with that socket. Did it?
    roweysvn
    roweysvn Member
    Dec 22, 2005
    455
    Thanks for your reply! No splitter/adapter was included with the TV unfortunately.
    Would you have a recommendation on what that adapter would look like?
  4. BuuBox
    BuuBox Member
    May 7, 2003
    9,648
    roweysvn
    roweysvn Member
    Dec 22, 2005
    455
    Appreciate the links to the cable/adapter. Excuse the ignorance, but will this still be able to carry 5.1 audio, or will this just be mono sound now?
  6. the_fuzz
    the_fuzz Member
    Sep 6, 2004
    9,796
    not sure why the confusion - its just digital via coax. You just need to plug your coax into the TV (yellow plug) and then into the coax plug on your logitech.
    you probably need to go into the settings of the TV and tell it your using digital out via Coax
    you shouldn't need any adaptors or anything like that
  7. Ryansta
    Ryansta Member
    Jul 7, 2016
    91
    The problem is it doesn't seem like the Coax on the tv is the same connector. Looks more like a 3.5mm jack
    roweysvn
    roweysvn Member
    Dec 22, 2005
    455
  9. the_fuzz
    the_fuzz Member
    Sep 6, 2004
    9,796
    both are 3.5mm - coax and rca are the same size, just a different standard in the actual cable.
    What happens when you use the "coax" ends of your toslink cable? In the settings you will need to tell the TV your using digital out (generally anyway)
    This seems to be made very complicated - but it shouldn't be?
    roweysvn
    roweysvn Member
    Dec 22, 2005
    455
    I used the coax/3.5mm end of the toslink cable on the TV end and no luck with the audio, however it wasn't going into the COAX jack, it was going into the optical port shown in this image - http://i.imgur.com/Qi7jLzI.jpg I checked the settings in the tv and it had SPDIF audio already enabled.
    I'll have another look this afternoon when I get home, I wasn't sure it was meant to be this difficult, but it could verywell be a case of user error!
  11. BuuBox
    BuuBox Member
    May 7, 2003
    9,648
    Your cable is SPDIF over optical (3.5mm optical to TOSLINK), your TV appears to output SPDIF over coaxial (so you need 3.5mm to RCA coaxial).
  12. the_fuzz
    the_fuzz Member
    Sep 6, 2004
    9,796
    yeah, coax to coax needs to be
    roweysvn
    roweysvn Member
    Dec 22, 2005
    455
    Definitely appreciate the help guys, I'll look into a 3.5mm coax into RCA coax
  14. Holdenkicks
    Holdenkicks Member
    Mar 30, 2003
    994
    Central Coast
  15. nico6
    nico6 Member
    Sep 9, 2005
    1,756
    melb.vic.au
  16. BuuBox
    BuuBox Member
    May 7, 2003
    9,648
    Nope, SPDIF is a digital standard.
  17. neoprint
    neoprint Member
    Jan 1, 2003
    444
    Cairns
    Digital yes, however actually getting 5.1 out of a TV for anything other than FTA TV or inbuilt apps can be an entirely different matter. The vast majority I've seen won't pass 5.1 to the coax/optical from HDMI inputs.
  18. nico6
    nico6 Member
    Sep 9, 2005
    1,756
    melb.vic.au
    So as long as it connected to a digital coax jack, the 'mono' spec of this cable is irrelevant? Cool!
