ASUS M4A89GTD-PRO REVIEW
Discussion in 'Overclocking & Hardware' started by Uncle-Fester, May 28, 2010.
  1. Uncle-Fester
    Uncle-Fester Member
    Jun 22, 2009
    826
    Perth W.A
    I recently received the ASUS M4A89GTD-PRO from ASUS Australia, It has been awhile since playing with an AMD setup and i must say it was great fun, reminds me of the old days when AMD were the kings. AMD was also very generous with giving me a AMD 555 cpu and KINGSTON donated a set of Hyper X 2000 c9 duel channel kit of memory. This new ASUS board is packed with extras USB 3 and SATA 6 RAID, Turbo unlocker and the biggest bonus the new feature called CORE UNLOCKER with a simple flick of a switch next to the ram sots you instantly unlock up to 4 core's from your duel core AMD CPU, No need to play with bios to unlock your cores anymore.
    OVERVIEW:
    KINGSTON DDR 3 HYPER X 2000 C9 DUAL CHANNEL MEMORY:
    SPECIFICATIONS:
    CPU
    * AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors, AMD 140W CPU Support, AMD Cool 'n' Quiet™ Technology, Supports 45nm CPU
    Chipset
    * AMD 890GX/SB850
    Memory
    * 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)*/1333/1066 Memory
    * Dual Channel memory architecture
    Expansion Slots
    * 2 x PCIe 2.0 x16 support ATI CrossfireX (dual x8 speed)
    * 1 x PCI Express 2.0 x4
    * 2 x PCI Express 2.0 x1
    * 2 x PCI
    VGA
    * Integrated ATI Radeon™ HD 4290 GPU
    * Multi-VGA output support: HDMI, DVI-D and RGB ports
    * Supports HDMI with max. resolution 1920 x 1200 (1080P)
    * Supports DVI with max. resolution 2560x1600 @60Hz
    * Supports RGB with max. resolution 2560x1440 @75Hz
    * Support H.264, VC-1, MPEG-2, DirectX10.1 and OpenGL2.0
    * Support Shader Model 4.1, Universal Video Decoder (UVD) 2.0
    * Max. UMA Memory Size: 512 MB
    * 128MB DDR3 1333 sideport memory support
    * Hybrid CrossFireX support
    Storage
    * SB850 Chipset
    6 xSATA 6.0 Gb/s supports RAID 0,1,5,10
    * JMicron® JMB361 PATA and SATA controller
    1x Ultra DMA 133/100 for up to 2 PATA devices
    1 x External Power eSATA 3.0 GB/s port
    Audio
    * ALC 892 8-Channel High Definition Audio CODEC
    - BD Audio Layer Content Protection
    - Support 192khz/24bit True BD Lossless Sound
    - DTS Surround Sensation UltraPC
    - Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
    - Optical S/PDIF Out ports at back I/O
    - ASUS Noise Filter
    LAN
    * Realtek® 8111E Gigabit LAN controller featuring AI NET2
    Rear Panel I/O Ports
    * 1 x DVI
    * 1 x D-Sub
    * 1 x HDMI
    * 1 x S/PDIF Out (Optical)
    * 1 x IEEE 1394a
    * 1 x LAN(RJ45) port
    * 8 -Channel Audio I/O
    * 1 x PS/2 Keyboard (Purple)
    * 1 x Power eSATA
    * 4 x USB 2.0/1.1 ports
    * 2 x USB 3.0 ports
    Internal I/O Connectors
    * 4 x USB connectors support additional 8 USB ports
    * 1 x IDE connector
    * 1 x IEEE 1394a connector
    * 1 x CPU Fan connector
    * 1 x Power Fan connector
    * 6 x SATA 6Gb/s connectors
    * 1 x Chassis Fan connector (4-pin)
    * 1 x Chassis Fan connector (3-pin)
    * 1 x S/PDIF Out Header
    * 1 x Core Unlocker Switch
    * 1 x Turbo Key II Switch
    * 1 x MemOK! Button
    * Front panel audio connector
    * 1 x COM connector
    * 1 x Clear CMOS jumper
    * 1 x 24-pin ATX Power connector
    * 1 x 8-pin ATX 12V Power connector
    * System Panel
    BIOS
    * 16 Mb Flash ROM , SPI, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
    Accessories
    * 1 x Ultra DMA 133/100 cable
    * 2 x Serial ATA 3.0Gb/s cables
    * 2 x Serial ATA 6.0Gb/s cables
    * 1 x Q-Shield
    * 1 x VGA Switch card
    * 2 in 1 Q-connector (USB, System panel; Retail version only)
    * User's manual
    TEST RIG:
    ASUS M4A89GTD-PRO MOTHERBOARD
    KINGSTON HYPER X 2000C9 DDR3 MEMORY
    ASUS GTX 285 MATRIX GPU
    CORSAIR HX1000 PSU
    AMD PHENOM X2 555
    WD 160GB HARD DRIVE
    OVERCLOCKING:
    The best stable overclock on this AMD Phenom X2 555 was 4013GHZ with 3 cores enabled, unfortunate i couldn't get 4 cores stable with an overclock but i was pretty happy with 4ghz from 3 cores. I was hoping i could get more from the RAM but the best i could get it to run at was 1856mhz with c9 seems to still be some memory clocking issues on AMD.
    BENCHMARKS:
    ROUND UP:
    I found this board to be great fun and playing with AMD again is a good refresh, overclocking on this board was extremely simple i also tested the auto AI TURBO overclock feature with gave me an instant stable 3.6ghz, I could not fault this board apart from the memory clocking i would have liked to achieved 2000MHZ + from this setup but it just did not seem possible.
    PRO'S:
    PRICE
    SATA 6
    USB 3
    TURBO
    CORE UNLOCKER
    CON'S:
    MEMORY CLOCKING
    BIG THANKS TO MATT FROM ASUS AUSTRALIA FOR THE MOTHERBOARD, KINGSTON FOR THE MEMORY AND AMD FOR THE CPU.
    UNCLE FESTER.
  2. MrSmoke
    MrSmoke Member
    May 22, 2008
    2,368
    NSW, Blue Mtns NizzleBiX
    lol looks like a gigabyte board with all that blue :p
  3. Goughy
    Goughy Member
    May 29, 2002
    197
    Say it with me... DUAL CORE :D
    Computers cores do not duel :leet:
    Uncle-Fester
    Uncle-Fester Member
    Jun 22, 2009
    826
    Perth W.A
    HAHAHAHA if only they did . sorry mate for the typo :)
  5. genesis
    genesis Member
    458
    NW, Tasmania
    Nice setup...
    Is the RAM set-up in the right slots? ?
    I could be wrong but should they be in alternate slots ?
    Uncle-Fester
    Uncle-Fester Member
    Jun 22, 2009
    826
    Perth W.A
    Yes that picture was done just as i was setting up and did put the ram in wrong :)
