Asus Sabertooth X58 Ram problem
Discussion in 'Troubleshooting Help' started by macarule, Dec 1, 2011.
  1. macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    Just got my ram for my X58 put it all in, installed the last bit which was my ram and it only read 4gb but when i look in CPU-Z it is reading 6GB ram in triple channel and mem test also shows all my ram but windows 7 and BIOS is reading 4gb ram so 2 things are telling me one thing and 2 are telling me the other, anyone got any idea? Ive updated BIOS, cleard CMOS reseat CPU and blown the port to clean it but still nothing :( any one know about it? :confused:
    Cheers
    Paul
  2. Dodoman
    Dodoman Member
    Feb 12, 2008
    2,363
    3145
    What version of Windows are you running? 64-bit or 32-bit?
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    64bit even if i was running 32bit that wouldnt effect the BIOS would it?
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    here it shows i have 6GB ram on 3D MARK vantage:
    but in windows control panel it says i have 4GB? also when i click system info on vantage it says i only have 4GB but in results it says i have 6GB :confused:
    something strange is going on here...
  5. Dodoman
    Dodoman Member
    Feb 12, 2008
    2,363
    3145
    I've run into a similar issue with my sabretooth as well. What I do is change the voltage/timings and suddenly the "missing" memory comes back. I don't know if this will help you though, and the problem corrected itself once I got some G.Skill RAM.
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    ive tried all of that :( sadly i still have missing ram :( ive contacts ASUS see what they say, they will probably send me a replacement board first problem i have come across on an ASUS board :upset:
  7. tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,441
    BIOS updated?
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    yeah to the newest one, one of the first things i did :Paranoid:
  9. tiro_uspsss
    tiro_uspsss Member
    May 10, 2007
    2,441
    :Paranoid: :thumbdn: yeah, I'd contact Asus :(
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    Already sent a inquiry off so lets see what they say :confused:
    its weird some programs are reading 6GB and some are reading 4GB
  11. Kurosaki
    Kurosaki Member
    Dec 8, 2005
    4,852
    Australia
    what slots are the ram plugged into?
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    A1, B1, C1 all the light coloured slots :thumbup:
    macarule
    macarule Member
    Feb 7, 2011
    124
    Perth Duncraig 6023
    okay well i got it to read all 6GB in bios and windows but the cards are in A1, C2 and C1 and it reads all 6gb but in dual channel and i would rather run 6gb dual channel than 4gb in triple channel so im guessing its just a buggered ram port? :confused:
  14. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    ADL/SA The Monopoly State
    X58 is extremely picky with any ram other than the cheap generic stuff <:
    This was super common back when X58 came out, most people changed brands.
  15. snappy1
    snappy1 Member
    Feb 18, 2008
    4,165
    Benching
    Increase your vvt/qpi voltage to 1.35v....
    I doubt they will replace the board, it is a known X58 issue, you need to tweak voltages
