Audigy 4 & KX Project Drivers
Discussion in 'PC Audio' started by ZoLi, Mar 20, 2007.
  1. ZoLi
    ZoLi Member
    Sep 19, 2002
    414
    Melbourne, Aus
    Hi All,
    Just wondering if anybody has used the KX Project drivers with there Audigy 4(non Pro). Im not sure if the hardware is supported by the driver as Im a little confused as to what sound processor the card uses.
    Im not at home (working) and cant really be bothered waiting until I get home to check (cant be a$$ed removing my case and fiddling).
    Anybody know if they work and are they any good compared to the drivers currently supplied by Creative. I used to use the KX drivers on my old Sound Blaster Live! card which sounded great after swapping the back channel to front to take advantage of the Phillips DAC (Even on Logitechs!)
    Now that I use Digital with dedicated amp and decent speaker setup will it be worth it if I swap?
    Cheers
    ZoLi
    ZoLi Member
    Sep 19, 2002
    414
    Melbourne, Aus
    Okay found that the card is partially supported.
    Question is; is it worth swapping to these drivers?
    Can anybody give me a reason why I should swap to KX? Or is it not worth it as Im using Digital?
