Audioengine D1 Premium 24-Bit DAC - Thoughts?
Discussion in 'PC Audio' started by Hodge, Jun 20, 2012.
  1. midyim
    midyim Member
    Mar 21, 2011
    15
    Brisbane 4034
    I am using a one meter USB & Optical...no problems
  2. Stonerboy779
    Stonerboy779 Member
    Jul 27, 2012
    201
    Melbourne, Australia
    The D1 has rca out which is perfect for my A5+ bookshelf speakers, it has a more than capable headphone amp too and it can sit on the desk in front of you and you can easy change volume much better than a pci-e soundcard ever will.
    If you had really high impedance headphones you would want something different (I am talking greater than 300ohm here tho) your headphones are 32ohm so they will be just right with the D1 and it is easy switching with the bookshelf speakers from the pre out because plugging in headphones stops output on the rca pre outs.
    If you want more than 2ch sound though you may want a soundcard but as you said that is for the future.
  3. AManEatingDuck
    AManEatingDuck Member
    Feb 7, 2002
    284
    Auckland, NZ
    hmm, everytime i use a 1m or 1m+ cable my D1 shows as an unknown device. I've tried about 4 different cables with it but always the same thing.
  4. DeejW
    DeejW Member
    May 18, 2008
    1,951
    Margaret River WA
    tried it on a different computer? might be a faulty unit
  5. AManEatingDuck
    Feb 7, 2002
    284
    Auckland, NZ
    I've just tried on a Dell E4300 with a 1m cable and the D1 works fine. But if i use the same cable on USB2.0 port on my ASRock z77 extreme 4 the D1 comes up as a unknown device. However if I plug the same cable in to a USB3.0 port on the ASRock the D1 works fine.
    Talk about weird.
  6. t8y
    t8y Member
    May 5, 2002
    4,311
    SA, 5011
    usb is slightly underpowered on the asrock perhaps.
    try another port (try them all..), maybe one has better access to power
  7. AManEatingDuck
    Feb 7, 2002
    284
    Auckland, NZ
    I've tried the 2 USB 2.0 ports at the back and they both do the same thing. Maybe i'll try the ASRock forum over at TT or OCW.
  8. krappo
    krappo Member
    Aug 25, 2008
    806
    Little Island
    i have Audio Engines 5+ and D1 Dac connected with supplied USB cable and not only works well but what a dramatic difference in sound all my music is in flac and the detail i can hear now is absolutely fantastic :):wired:
  9. PrinceCharming
    PrinceCharming Member
    Dec 12, 2005
    301
    Is this worth getting if I use it to connect to my LCD TV with the older Audioengine A5s and Beyerdynamic DT250 headphones?
    I have my Blu ray player, Xbox 360 and a media connected to the TV via hdmi. Then the Audioengine A5s are connected to the headphone out on the TV via 3.5mm.
  10. PrinceCharming
    Dec 12, 2005
    301
    Just wanted to clarify my question. Would there actually be any benefit in connecting an Audioengine D1 to my TV or are these more for PCs and MACs? Never used an external DAC before.
  11. t8y
    t8y Member
    May 5, 2002
    4,311
    SA, 5011
    i imagine youd need to power it via USB somehow (if not from the TV/BD, then maybe a wall adapter?), and use the optical for the input.
    you likely wont be able to use sound via the USB cable as they arent PCs, wouldnt know what to do with it.
    they arent really designed for what you want but if configured like that they should work?
    probably better solutions though, like an actual HT amp perhaps..
    i just ordered one of these to go with my ad-700s. finally i can be done with onboard sound :)
  12. PrinceCharming
    Dec 12, 2005
    301
    My AE A5/TV have USB ports so that wouldn't be an issue. My TV has optical out so I would connect it via that if I did get the D1. HT amp is over my budget :(
    Man, I spent the whole night googling and I still don't know lol
  13. Benno1988
    Benno1988 Member
    Oct 30, 2007
    5,358
    Optical to D1. 240 to USB adapter to power it. All good.
    Might work powering it off TV with USB. Might also get confused to what input to use and not work.
  14. PrinceCharming
    Dec 12, 2005
    301
    Do you think there would be any improvements in audio quality if connected to the TV instead of a PC or MAC though? That't the main thing I'm concerned about
  15. t8y
    t8y Member
    May 5, 2002
    4,311
    SA, 5011
    ok, mine arrived today, just hooked it up (just via USB)
    fired up scott pilgrim versus the world bluray, opening 5mins.
    only one way to describe - http://youtu.be/RiX4FAQC9cg
    they are still ringing, probably shouldnt have turned it right up lol
    tested with a few other movies of various source material (at a lower volume..), it has totally kicked these ad700s up another notch. night and day difference between it and the goddamn 'realtek HD' onboard.
    manual claims it needs to wear in for about 40~50 hours, and it only gets better from here.. :D
  16. Nitecore
    Nitecore Member
    Jun 3, 2009
    188
    Hijacking thread =P
    Would it be a waste of money to buy one when I've got a Asus HDAV 1.3 Deluxe?
  17. Dr Evil
    Dr Evil Member
    Oct 20, 2010
    2,891
    Yer I'm also interested to know if its worth selling my Asus Xonar STX card for this lil Dac.
  18. Benno1988
    Benno1988 Member
    Oct 30, 2007
    5,358
    Unless the D1 is more convenient, no. The DAC wouldn't be better, and the headphone amp is just as powerful. I got one because I wanted a external DAC.
  19. orby
    orby Member
    Jul 7, 2008
    624
    Marrickville
    I read this review http://www.computeraudiophile.com/blogs/david-parker83/audioengine-d1-versus-dacmagic-116/
    Dacmagic vs the d1, and it seems that the d1 came out on top because of the price. However someone here rated the xonar essence one as being substantially better than the d1.
    Lost my soundcard because of mitx and I can't stand the onboard sound. I need an external dac and always wanted the dacmagic plus. Could someone recommend the d1 or the essence one over the dacmagic?
    Mostly use the ad900 but also have grado rs1's which I should probably amp up in future.
    There's a bunch of other dac's on headphonic for under $500, should I consider those?
  20. Mad Mike
    Mad Mike Member
    Jun 30, 2001
    780
    I spent the weekend researching the same thing, was going to post that same question today. Any thoughts would be great.
