AutoCAD help
Discussion in 'Graphic Design & Digital Art' started by Spl@, Apr 23, 2009.
  1. Spl@
    Spl@ Member
    Jan 27, 2004
    400
    Zürich, Switzerland
    Hey guys, not really a member of any other forums, so I thought I'd post here before signing up to 100 other sites.
    I'm working in landscape architecture, and need to construct lines along a curve. each line needs to be perpendicular to its intersection point on the curve, and all at 800mm intervals along the centreline. I've tried the Measure tool, but then I am left with 1000 lines to rotate to 90degrees..
    Can anyone please help with this situation?
    Thankyou
    Ryan
  2. RichoB
    RichoB Member
    Sep 29, 2005
    540
    use the measure tool, but insert a block (the block can just be a simple line). Make sure you align the block to the string you're 'measuring'.
    if it's a single radius curve, you can give the array command a go as well.
  3. randomman
    randomman Member
    Oct 21, 2007
    5,165
    Vancouver, BC
    I'm trying to make sense of what you want to do...
    Do one line and then use the offset command.
    Oh and PS Ryan, tell some Swiss chicks to come to Perth, we need to even out the bogan:normal ratio.
    Spl@
    Spl@ Member
    Jan 27, 2004
    400
    Zürich, Switzerland
    You Sir (RichoB), are my bloody hero. Thankyou so much!!!!
