Average FTP upload speed
Discussion in 'Networking, Telephony & Internet' started by [AFX]Northy, Dec 14, 2018.
  1. [AFX]Northy
    [AFX]Northy Member
    Sep 24, 2003
    1,143
    Hi Guys,
    had my NBN setup yesterday (100/40 HFC) and I have FTP setup on my NAS (DS213j) and I am only getting 10-15mbps when downloading remotely. Speeds are pretty consistent but I was wanting to get closer to the 40mbps upload limit on my connection. Router is an Archer C3150, Any ideas?
  2. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,441
    BRISBANE
    PASV enabled? I think active is faster.
    rDNS setup properly?
    [AFX]Northy
    [AFX]Northy Member
    Sep 24, 2003
    1,143
    Passive is not being used and DNS is correct. Seems to be a limitation of my router perhaps?
  4. syx
    syx Member
    Jul 30, 2001
    590
    Mount Gambier
    is that the same upload speed as when you do a speed test from home ? eg, around 15 ? if so then could be router.
    do you get full speed when home to your ftp ? (internal network)
  5. Arctic_Silver08
    Arctic_Silver08 Member
    Aug 11, 2012
    1,298
    Program you're using?
    How many files?
    I've had better throughput with 10 files simultaneously on Filezilla as opposed to 1
  6. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,441
    BRISBANE
    DNS != rDNS, check with your ISP if you've got reverse DNS setup properly for your IP.
    [AFX]Northy
    [AFX]Northy Member
    Sep 24, 2003
    1,143
    I am getting pretty much full speed on my NBN and when I test via FTP on the lan the transfer speeds are over 100mb's so the NAS can do it.
    I have tried multiple smaller files and also a single larger file, The total upload remained the same.
    I tried connecting with the IP address and it made no difference.
