bayonet light socket - 240 v adapter?
Discussion in 'Electronics & Electrics' started by Appius1, Feb 16, 2009.
  1. @rt
    @rt Member
    Nov 30, 2005
    2,329
    I made one out of a smashed light bulb as a teenager so I could use it
    to power a fluorescent tube assembly that just had flying leads.
    Worked great! My PVC electrical tape job must have held up.
    I was also renting, and was afraid to alter the house,
    but wanted all the wiring on the roof and controlled by the light switch
    rather than just use an outlet.
    Needless to say I wouldn't go about it the same way now.
  2. rickbishop
    rickbishop Member
    7,415
    Petrie, QLD
    Is there anything special about it, or is it just a normal 100w light bulb?
    If it's just a normal 100w light bulb, I'm somewhat curious as to why you would want to keep it.
  3. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    4,706
    Brisbane QLD
    You don't need to put quotes around it - they are terribly inefficient. You do know you can get all different types of flouro bulbs now that will more than likely give you the colour you want?
  4. paulvk
    paulvk Member
    Mar 10, 2010
    1,063
  5. maddhatter
    maddhatter Member
    4,798
    Mackay, QLD.
    Worth noting that light circuits are generally not wired into your RCD switch either...
  6. Symon
    Apr 17, 2002
    4,706
    Brisbane QLD
    In houses built after 1986 they are.
    IntelInside - fair enough, I would just get a small fan heater, and leave it on the low setting.
  7. rickbishop
    rickbishop Member
    7,415
    Petrie, QLD
    What kind of reptiles?
    Although more costly in the short term, perhaps a heat mat would be cheaper in the long term, and safer for the inhabitants of the enclosure.
  8. LeadAccelerator
    LeadAccelerator Member
    Aug 10, 2008
    837
    Try a PC PSU and some ceramic resistors, either use the 12VDC output if it can provide enough amps or the 5VDC output which will provide enough amps.
    Send me a PM if you are after ceramic resistors, I have them rated from less than 1W up to 20W or so each and 3 300W PC PSU's.
    You would just need a thermostat which Oatley should have that can switch the PSU on and off.
