Behind panel lighting
Discussion in 'Audio Visual' started by Cypher, Jan 15, 2010.
  1. damo2002
    damo2002 Member
    Jul 9, 2007
    226
    Melbourne, 3085
    I reckon that idea sounds pretty good, Kyl3. Although I'd probably make it a bit bigger than 10cm.. don't think that would be enough space for the light to evenly fade out. It'd probably just end up being a thick bar of light around the TV.
    Probably better off checking eBay, goodguy. Ikea seem to sell 'em for about $100 for 1m, compared to about $25, with remote etc.
  2. goodguy82
    goodguy82 Member
    Feb 28, 2006
    4,861
    so many to choose from on ebay! any seller you would recommend to buy from:confused:
  3. damo2002
    damo2002 Member
    Jul 9, 2007
    226
    Melbourne, 3085
    No idea to be honest! Mine haven't arrived yet (only ordered a few days back), but I just ordered one of these. I just found the length I wanted, with included power supply & remote, then searched for who had it cheapest. I doubt there's any difference from seller to seller. :thumbup: Even up to 5m worth is cheaper than Ikea though..
  4. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    33,406
    A Reported Post Near You
    Cypher
    Cypher Member
    Aug 4, 2001
    1,787
    North of Brisbane
    Cypher
    Cypher Member
    Aug 4, 2001
    1,787
    North of Brisbane
    Got the controller going!
    Just have to get some bits from jaycar tomorrow so it'll do the 12v required for the LEDs...
    Might look into some kind of ambient light sensor too, so it automatically dims the light as needed.
  7. scottath
    scottath Member
    Aug 16, 2007
    2,575
    so how are you powering these?
    im assuming they are 12v or something low voltage....
  8. thegumbyman
    thegumbyman Member
    Sep 23, 2009
    35
    Hobart
    I found the philips technology quite fascinating.
    Cypher
    Cypher Member
    Aug 4, 2001
    1,787
    North of Brisbane
    They run on 12v, I'm just using a 12v 1a power pack I had lying around.
  10. scottath
    scottath Member
    Aug 16, 2007
    2,575
    wish i had one of them lying around - storm killed my routers one....:(
  11. Snuffy22
    Snuffy22 Member
    Sep 1, 2004
    652
  12. arrow224
    arrow224 Member
    Oct 16, 2004
    1,889
    Outer SE Melbourne
    PHWOAR!!!!!! F*&!ing awesome man!
  13. stevo4
    stevo4 Member
    10,631
    Looks as if the lighting is too bright.
    The reflection off the side panels would be a distraction.
  14. Snuffy22
    Snuffy22 Member
    Sep 1, 2004
    652
    yeah the photos are really bad, the brightness can be adjusted of course but i like it up bright, I don't find it distracting :)
  15. stevo4
    stevo4 Member
    10,631
    Fair enough. :)
    I like the effect, but dont think I could handle it being much brighter than a faint glow in the background.
  16. gmanofau
    gmanofau Member
    Sep 3, 2002
    132
    Hi Snuffy where did you get your lighting equipment from, are they the strips or tubes.
    Cheers
  17. Snuffy22
    Snuffy22 Member
    Sep 1, 2004
    652
    ebay shop
    i got this (about $70 shipped)
    cut strips for behind the speakers and soldered them onto some wire to the TV strip etc
    very very easy install
  18. gmanofau
    gmanofau Member
    Sep 3, 2002
    132
    Thanks for the reply, I can use a soldering iron very basic skills done a few car audio installs, how a safe is will it be with the soldered wires, not to keen to set my house on fire :p
  19. Snuffy22
    Snuffy22 Member
    Sep 1, 2004
    652
    if your only planning to put the led's behind your tv you wont need to solder, if you do solder just wrap the soldering in electrical tape afterward if your worried, the whole system only takes 0.8amps, crap all
  20. OZNETiCS
    OZNETiCS Member
    Feb 9, 2006
    101
    i got some left over from sample order if anyone likes. I have them in 30cm strips though.
    rgb with controller and remote and power pack
