Bench mounted a belt sander
Discussion in 'Hobby Engineering' started by Andrew_Wong, Feb 9, 2021.
  1. Andrew_Wong
    Andrew_Wong Member
    May 6, 2008
    176
    Perth, Australia
    I've had a Makita 9403 belt sander for a while, and it's now got a new job for sanding small parts !
    With the new bench mount, belt changes are a one handed affair!
  2. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,613
    Nulkaba
    Looks good
    Andrew_Wong
    Andrew_Wong Member
    May 6, 2008
    176
    Perth, Australia
    So here's the big brother.. going to hook up an old VSD and see if the caps in it are still OK.. otherwise will have to get a new Powtran.
    Agg, Witters, GumbyNoTalent and 2 others like this.
  4. philquad
    philquad Member
    Jan 22, 2004
    1,584
    nelson bay
    sick, that'd be great to do knives on
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,613
    Nulkaba
    now thats a linisher:)
  6. havabeer
    havabeer Member
    Dec 12, 2010
    6,376
    did you make all the parts your self? or buy it as a kit/download plans.
    very nice work either way
  7. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    12,852
    viva brisvegas
    Geez dude, ya could have used decent thickness steel! lol ;)
    Over-engineering at it's finest!
    Andrew_Wong likes this.
    Andrew_Wong
    Andrew_Wong Member
    May 6, 2008
    176
    Perth, Australia
    Thanks - it’s my first real machine I’ve built.
    The original design was the Jeremy Schmidt grinder but customised it to simplify - he didn’t have a plasma cutter. The steel parts are all cut from 10mm plate. Bought the wheels from AliExpress. My mate found us some cheap 2.2kw grundfos motors and I had an old 1-3ph VSD lying around.
    The parts cost excluding the plasma cutting was probably about $600 ($100 steel/fasteners $50 motor $250 wheels $200 VSD.
    Jeremy gave me the fusion360 model when I bought his plans and this led to the custom parts like the platen. It’s great to work with the 3d model as you can redesign a part and it still fits exactly.
    GumbyNoTalent likes this.
  9. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    3,019
    Bet that thing weighs a ton with those thick gauge steel plates.
  10. dirtyd
    dirtyd Member
    Jan 4, 2006
    4,086
    Melbs
    Must be your first time in an Andrew_Wong thread - everything gets 10mm plate! It's ridiculous but great :D
    Andrew_Wong
    Andrew_Wong Member
    May 6, 2008
    176
    Perth, Australia
    Have designed the stand.. have to fit the VSD somewhere where it won't get dirty.. Analog pot to control speed .. And a place to hang my angle grinders
    3mm sheet metal and SHS tubing.. sadly no 10mm on the stand.
    Andrew_Wong
    Andrew_Wong Member
    May 6, 2008
    176
    Perth, Australia
    So heres the stand.. will make the angle grinder holders next weekend. have to work on the robot during the week!
    mad_mic3 likes this.
