Best 32" (or 31.5), 1440p, 144+hz monitor
Discussion in 'Video Cards & Monitors' started by Coolio, Apr 6, 2020.
  1. Nethiuz
    Nethiuz Member
    Oct 3, 2019
    3,107
    Cairns
    Azzan likes this.
  2. Ap0c
    Ap0c Member
    Apr 29, 2003
    1,206
    Melbourne, 3136
  3. Nethiuz
    Nethiuz Member
    Oct 3, 2019
    3,107
    Cairns
    It was that good!
  4. Loadingdread
    Loadingdread Member
    Feb 11, 2010
    818
    Parramatta
    After reading this thread I bit the bullet and ordered a dell S3220DGF. Now we wait for delivery.
    Coolio
    Coolio Member
    Apr 11, 2004
    413
    Mine arrived the other day (about a month before they said it would). Quite happy with this monitor :) Much better pictures and colours than my old TN panel and I can't really see any motion blur when I'm gaming.The curve is great too! Still I may sell it and get an Odyssey G7 when they release.
  6. Loadingdread
    Loadingdread Member
    Feb 11, 2010
    818
    Parramatta
    Mine got delivered today. Really happy with it and a vertical 23 inch monitor next to it. The curve is pretty fantastic. I'm currently driving it with a laptop with a 1060 in it and its struggling to keep up the frames with Freesync but once I get my gaming PC to my new place I think it should go well.
  7. Scotty_DDR
    Scotty_DDR Member
    Oct 9, 2006
    1,103
    The Isa
    eBay coupon back on the dell PDPC20 only brings it down to $799
    Coolio
    Coolio Member
    Apr 11, 2004
    413
    Seems like they've raised the price from 749 to 999. Try sending them a message on ebay asking for a custom order at 749, then you can apply the coupon to bring it down to 599. I had success asking them to sell me the monitor using the discount when it was out of stock...
  9. die_piggy
    die_piggy Member
    Feb 18, 2008
    831
    If this actually works, could someone let me know?
  10. Loadingdread
    Loadingdread Member
    Feb 11, 2010
    818
    Parramatta
    I can post my dell invoice for $699 if anyone wants it.
  11. MagyaR
    MagyaR Member
    Jan 15, 2004
    5,765
    Melb
    Anyone recommend the ViewSonic Ultra-Slim VX3276-2K 32" WQHD IPS LED Monitor?
    Little gaming, more for Ableton and video editing.
  12. die_piggy
    die_piggy Member
    Feb 18, 2008
    831
    Loadingdread yes please!
  13. Zarok77
    Zarok77 Member
    Jan 2, 2020
    1,160
    i have 3 monitors 1080p 144hz, 1440p 165hz, 4k 144hz.
    When i use my 4k 144hz the gpu usage is always 98% and that's what i want for my 2080ti.
    Even if my settings are low and medium in order to fill 144hz on my Xv273k, 4k res medium still better than 1440p ultra. If that make sense...
  14. DeltaRZ
    DeltaRZ Member
    Apr 29, 2020
    5
    Good 32 1440p 144Hz don't exist. All of them are VA panels with noticable smearing. IPS models are at least 1-2 years away, there is one base panel being manufactured.
    Going by monitor discussion sites, the LG 32GK850F-B had the least smearing and even it was often hitting 16-33ms on some black-grey transitions. A samsung i can't remember came second. Look for the transition tables.
    Monitor researching was more annoying than the rest of the pc parts put together.
    32 inch 1440p is the exact same pixel size as 24 1080p so it is by no means a bad choice.
  15. Zarok77
    Zarok77 Member
    Jan 2, 2020
    1,160
    i think 32" 16/9 is to big for 1440p.
    I also had aoc CQ32G1 in the past, ditched for predator xb1 27.
    They say:
    24" 1080p
    27" 1440p
    32" 4k
  16. ToonarmY
    ToonarmY New Member
    Apr 28, 2020
    22
    There is an ultra wide acer nitro xv340ck 1440p 34" IPS which just came out. Iv made a post on it
  17. DeltaRZ
    DeltaRZ Member
    Apr 29, 2020
    5
    Doesn't count.
    UW doesn't count in general, but even ignoring that,
    34 inch wide works to be the same height as a 16:9 27 inch, it's not the same physical sized pixels as 32 thus not compariable. I believe it was 42inch 21:9, as 32inch = 41.5cm high ( 24inch = 31cm h) for same pixel density, and at that panel size no one makes 41cm h x 1440p h IPS, there' only 1600p or 2000p IPS, or 1440p VA.
  18. ToonarmY
    ToonarmY New Member
    Apr 28, 2020
    22
    Err ok. People just want to buy a good monitor dude.
  19. DeltaRZ
    DeltaRZ Member
    Apr 29, 2020
    5
    The OP specified 32, i'm just pointing out 34 UW is not 32, it's 27.
    I spent days once looking for a good 32" 144hz 1440p, only to find they don't exist, it's all VAs. As some have said, a few good 32s are in development.
    This is the best 32 atm and even it is not good. Anything over 1000/144 is painful.
    https://www.tftcentral.co.uk/reviews/lg_32gk850g.htm
    Some monitor chatrooms had more tables.
    I also don't see you contributing anything of value to this thread with that post...
  20. ToonarmY
    ToonarmY New Member
    Apr 28, 2020
    22
    I too wanted a monitor of that spec but not in VA and also found it does not exist. Hence the alternative suggestion which ticks all the boxes and adds more...
    I think the OP can decide what is useful to them
    terroristone likes this.
