Best 7.1 gaming sound card via optical?
Discussion in 'PC Audio' started by super kermit, Sep 3, 2017.
  1. super kermit
    super kermit Member
    Jun 18, 2002
    987
    Sydney Pyrmont
    I ma running into a yamaha 7.1 receiver via optical.
    What is the best soundcard for this?
    I have 2 x gfx cards with HDMI in SLI so running optical via HDMI won't work from my research.
    I know my signal is compressed via optical.
  2. deluxe
    deluxe Member
    Dec 9, 2003
    454
    Are you using hdmi out for your video signal?
    super kermit
    super kermit Member
    Jun 18, 2002
    987
    Sydney Pyrmont
    No
    DP to the monitor
    Currently, Soundblaster Z via optical to the receiver.
  4. deluxe
    deluxe Member
    Dec 9, 2003
    454
    No soundcard needed for digital- if you continue using optical, the onboard optical out is fine, assuming you use the receiver for both speakers and cans?
    HDMI is better- higher bandwidth than optical. You should be able to use a HDMI connection direct to the receiver, it's worth a shot.
    1. check your playback devices list
    2. connect via hdmi cable
    3. set HDMI output as the default playback device
    4. run speaker setup to tell windows to send 7.1
    I know some people report problems with SLI+hdmi out on nvidia. Do you have hdmi on your motherboard?
    If not, do you have a spare pcie slot? Other solution is to run a third GPU -doesn't need to be anything with 3d muscle- and use it's hdmi out for audio
