Best batt to be left in device (for years)
Discussion in 'Electronics & Electrics' started by xc351, Nov 18, 2018.
  1. xc351
    xc351 Member
    Dec 30, 2005
    2,408
    Mate just had a 9v leak in his safe keypad terminals. So I had to solder in a new set sure easy job but not fun worried about pulling the terminals off.
    So anyways looking for a LONG life battery that can stay installed for years. Mine has key backup so it’s not to bad.
    I run energiser industrials he had some Chinese crud that came with safe years ago.
  2. dakiller
    7,794
    Gippsland
  3. merlin13
    merlin13 Member
    Apr 12, 2003
    1,804
    back in BrizVegas
    Spot The Deliberate Error...
    Sneaky trick I do when I know the batteries are going to be fitted long-term is apart from not using cheap 'n cheerfuls is an appropriate smear of good contact grease on the terminals at each end. Even a dab of Vaseline if the contact grease isn't within in arm's reach.
    That way even if the battery does shit itself and start bleeding, what comes out usually won't attack the metal connectors...
