Best prepaid solution for internet+calls
Discussion in 'Mobile Phones & Devices' started by Drew_, Mar 23, 2009.
  1. Drew_
    Drew_ Member
    Feb 20, 2007
    2,045
    Hey,
    Ideally I need a prepaid service with internet on a single sim card.
    I only need maybe 100Mb data a month, probably less.
    Most calls will be inbound, maybe 24 outbound calls a month.
    I have a hand full of Sony K800s that will tether with the tablet PCs to provide them internet access, which will be used for email.
    Using the USB keys/modems for internet access is not an option, as they will just break pretty quickly. Thus using bluetooth to tether phone to laptop.
    What would be my best option?
    Am I also right in assuming what I don't use one month on my prepaid carries onto the next month with both calls and internet?
    I'd rather not go on a plan, as this will be used by casual staff and some sims may go a few weeks to over a month without use.
    Also with prepaid is there a way to check the usage both calls and internet data used, remaining credit etc etc using like an online account manager.
    I'm hoping to get 100mb and 24 outbound calls for about $20 a month per sim
    Thanks,
    Drew
  2. BuuBox
    BuuBox Member
    May 7, 2003
    9,429
    Telstra
    $20 recharge, use $10 to buy a 100MB datapack, then have $10 left for calls as well as either 1c text to Telstra mobiles or 30 minutes of free calls to Telstra mobiles.
    You could use the left over $10 to buy one or a combination of the other "Plus Packs", for example: 1 x $5 Text Pack and 1 x $5 talk pack.
    This would give you 100MB + 30 SMS + 10 Minutes + Telstra Mobiles: 1c or 30 minutes.
    If calls are more important than SMS, get the $10 talk pack instead, which gives you 25 minutes.
    http://www.telstra.com.au/mobile/prepaid/pluspacks.html
    http://www.telstra.com.au/mobile/prepaid/latestoffers/index.html
    Online account stuff is all there too. Confusing? Slightly... :)
  3. sanjay
    sanjay Member
    Mar 10, 2004
    15,887
    Maribyrnong, Melbourne
    only prob is that the K800is the OP has arent next-g capable, thus he will need new phones.
    Drew_
    Drew_ Member
    Feb 20, 2007
    2,045
    My current one works fine for net access with Telstra, it connects at 3G speeds so its fine
  5. BuuBox
    BuuBox Member
    May 7, 2003
    9,429
    Telstra GSM and Telstra 3G (the 3GIS network) will work fine with the K800i.
    I checked the Optus option, but it'd be $30 a month.
    Virgin don't seem to offer data with their beancounter plan, otherwise that may have been okay.
  6. sanjay
    sanjay Member
    Mar 10, 2004
    15,887
    then its ideal - telstra 3g must still roam on three's 3g network (they had a joint partnership ages ago and i wasnt sure if it was still going).
    Drew_
    Drew_ Member
    Feb 20, 2007
    2,045
    Well I lie; it worked 6-9 months ago.
    I use a HTC Diamond now.
    I'll ask Telstra tomorrow about it
  8. BuuBox
    BuuBox Member
    May 7, 2003
    9,429
    It'll work fine.
  9. Falls
    Falls Member
    3,287
    Gun Cat @ Bikini Atoll
    You could try TPG Executive Mobile cap for $79.95. $2000 of calls and 2gb "free data" download.
    I used my TPG 49 cap saver sim with my e220 3g modem, worked fine @ 3g speeds.
    F.
  10. Protagonist
    Protagonist Member
    Sep 18, 2004
    317
    Fairfield, Sydney, NSW
    Wait, so I recharge $20, and that gives me $10 for data/web surfing and the other $10 for calls/sms?
    I am currently with iSim prepaid for their cheap rates, and have just updated the mobile to the E71, so looking at surfing the net with it, like the OP.
  11. BuuBox
    BuuBox Member
    May 7, 2003
    9,429
    More or less, but in my senario I was taking full advantage of the Telstra prepaid "Plus Packs". Makes Telstra prepaid quite well priced, but you have to make the most of 'em.
  12. BlackTigerTech
    BlackTigerTech (Banned or Deleted)
    Jan 27, 2008
    61
    2040 Sydney
    If you can wait a wee little bit, my pinkies says this will be on offer soon...pm me if you want more info and I'll see what I can do:thumbup:
  13. Deltoid
    Deltoid Member
    May 24, 2003
    9,515
    I'm also looking for a dataplan.
    I've got an E71 and am with iSim.
    Exetel's HSDPA plan looks pretty good (pay $5 a month min spend), data charges work out to $15 for 1Gb. Call rates are alright.
    I'm just not sure what happens when you roam out of their network.
  14. Deltoid
    Deltoid Member
    May 24, 2003
    9,515
  15. Deltoid
    Deltoid Member
    May 24, 2003
    9,515
