Best Pump/Res combo for beginner
Discussion in 'Extreme and Water Cooling' started by Nedstark, Jan 20, 2015.
  1. Nedstark
    Nedstark Member
    Jul 20, 2014
    23
    Hi All,
    I am looking to get a pump/res combo for my first open loop system. I am very new to it all.
    What is the best pump/res combo I can get for $100 or less? I only have 1 free 5.25" bay so it cant be a double bay res.
  2. mshagg
    mshagg Politburo
    May 8, 2007
    23,089
    What case and what kind of loop?
  3. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,379
    Cheltenham VIC
    as above - how long is a piece of string kind of question...
    If you can stretch your budget, you could get something like this as a bayres combo thing...
    Or if you are still stretching the budget, and you have room in your case for a cylinder res, get something like this
    but depending on your set up, both of those might not work
    Nedstark
    Nedstark Member
    Jul 20, 2014
    23
    I have a Fractal R4.
    At the moment my loop is just going to be for my CPU to a 240 radiator, but later on down the track I plan to include my graphics card.
    I will most likely upgrade the pump then though as I will have a bit more money when I WC my gpu.
  5. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,379
    Cheltenham VIC
    Fractal R4's aren't great for watercooling if you aren't ready to do some modding as far as I can tell...
    I had one a while back, but I was using an external RAD
  6. bobster
    bobster Member
    Nov 11, 2011
    1,027
    Nedstark
    Nedstark Member
    Jul 20, 2014
    23
  8. zero_velocity
    zero_velocity Member
    Sep 16, 2010
    2,883
    QLD
    Been there, done that, and I will say save your money and fork out for the pump you want NOW, not later.
  9. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    2,494
