Best way to convert long youtube video to audio
Discussion in 'Other Operating Systems' started by antipody, Jul 7, 2013.
  1. antipody
    antipody Member
    Jul 28, 2001
    5,039
    Small World
    Want to as quickly as possible do this, preferably between two time points that can be sent with the url.
    Checking google now, but most of the top its I get say it's either too long, ask me to install a java applet or just don't work.
    Thought I'd see if anyone here has done something similar. What's the fastest way to do this with, say a 2hr+ video?
    (Hope this is the right forum, not sure where to post this, but I thought it might be possible from my ubuntu terminal somehow...)
    Edit - http://mp3ify.com/ appears to have created a 250MB file I'm downloading now, so fingers crossed...
  2. Bastard Child
    Bastard Child RIP
    Jan 3, 2006
    3,624
    Crooklyn 3012
    I use dirpy, never tried it for anything other than music files.
    For a decent choice of video/audio rippers type "pwn" before the word YouTube, or dump the link to pwnyoutube.
    antipody
    antipody Member
    Jul 28, 2001
    5,039
    Small World
    Both mp3ify and convertmemp3.com appear to have worked(250MB for the former, 130MB for the latter), although pwnyoutube seems like the best solutiuon by far... going to have to grab it in a video format on that one now - thx!
  4. MooGliSH
    MooGliSH Member
    Mar 24, 2006
    901
    Melbourne, Vic
    JDownloader
  5. HyRax1
    HyRax1 ¡Viva la Resolutión!
    7,953
    At a desk
    1. First, make a local copy of the YouTube video in question using a tool such as ClipGrab.
    2. Now download MPlayer for your OS platform.
    3. Now open a terminal and tell MPlayer to play the video and dump out the audio track into a separate WAV file:
      Code:
      mplayer -vc null -vo null -nocorrect-pts -ao pcm:fast:waveheader MyYouTubeVideo.MP4
      ...the WAV file will be named audiodump.wav in the same directory.
    4. Now use a tool such as Audacity to convert that WAV file into your preferred format such as FLAC, OGG or MP3.
    5. Pat yourself on the back.
  6. MooGliSH
    MooGliSH Member
    Mar 24, 2006
    901
    Melbourne, Vic
    Why on earth would you transcode from a lossy source :p
  7. HyRax1
    7,953
    At a desk
    He wanted a solution - I gave him one. Personally I never rely on YouTube for getting music.
  8. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    160,152
    Omicron Persei 8
    Youtube is always only the very very last resort for me if I cannot get it elsewhere.
    antipody
    antipody Member
    Jul 28, 2001
    5,039
    Small World
    Because that's the only source of the file I wanted to listen to. It's not music, just a lecture, so not too concerned about quality.
    Thanks for the posts, some great solutions here. :thumbup:
  10. MooGliSH
    MooGliSH Member
    Mar 24, 2006
    901
    Melbourne, Vic
    I only say it because JDownloader afaik rips the audio directly from the container, rather than transcoding on the fly like most websites/that technique.
  11. gdjacobs
    gdjacobs Member
    Apr 3, 2007
    2,736
    MB, Canada
    Even modify this by using -dumpaudio to dump the audio stream, but this doesn't work all that great for AAC audio. More reliable is ffmpeg with the 'copy' codec. Just make sure that you dump whatever the audio is to the correct container.
