BH5 advice
Discussion in 'Storage & Backup' started by <pRo>ToSs, Oct 18, 2005.
  1. <pRo>ToSs
    <pRo>ToSs Member
    Sep 22, 2003
    3,546
    SING
    Are all BH5 ram the same? does it really make THAT much differance which PCB theyre using? Which ones do you guys reckon are particularly good value for money? I was lookin at the Team Xtreem ones
  2. SnooP-WiggleS
    SnooP-WiggleS Member
    Sep 20, 2004
    3,246
    Ballarat, Victoria
    mostly no. they're usually all brainpower pcbs anyway since they're cheaper to make and better. the team xtreem ones are meant to be good, and my ocz value vx goes well, probably needs more volts to fly but i'm not to bothered about memory speed
  3. ArcTan
    ArcTan Member
    Dec 23, 2001
    4,694
    if you're talking about UTT then they're basically the same depending on how they're speed binned. a bp pcb will probably be a few mhz better than a reference pcb
    <pRo>ToSs
    <pRo>ToSs Member
    Sep 22, 2003
    3,546
    SING
    The OCZ value VX ones are more expensive than the Team Xtreme ones.. is there a reason or is it just the brand?
  5. ArcTan
    ArcTan Member
    Dec 23, 2001
    4,694
    yeah just the brand
    though skycomp.com.au have the ocz cheaper by $6
    <pRo>ToSs
    <pRo>ToSs Member
    Sep 22, 2003
    3,546
    SING
    are all winbonds and UTTs BH5s?
  7. ArcTan
    ArcTan Member
    Dec 23, 2001
    4,694
    no
    they are either winbond BH UTT or CH UTT
    there is no original BH5 for a few years now
    BH is similar but don't overclock well on axp and intel machines
    plus they might not handle high voltages for long periods but thats still to be determined
  8. Black_Magic
    Black_Magic Member
    Oct 19, 2005
    121
    sydney
    what mobo is it going on? there are a couple of reviews at xtreme systems about the team memory.
    <pRo>ToSs
    <pRo>ToSs Member
    Sep 22, 2003
    3,546
    SING
    Its meant to be going on the Asrock 939 DUAL-SATAII. I'm gonna volt mod it/chuck a DDR booster on it, so it'll get a minimum of 3.09V to vdimm.
