BIG GUIDE TO BBQ (What to buy Help)
Discussion in 'Geek Food' started by sgtraven, May 27, 2014.
  1. mmBax
    mmBax Member
    Oct 26, 2011
    3,038
    I put mine on a 3 ring gas burner that I use for homebrewing, if I'm mega impatient, once they start glowing I crank the heat gun into it.
  2. josh1990
    josh1990 Member
    Mar 18, 2014
    1,251
    Albury, NSW
    Look around, I got 3 for $45 ($15 each) at Bunnings in Albury :thumbup:
    I've heard they are horrible at keeping temperature over a period of time, they put more people off charcoal BBQ than they get interested. The poor (in comparison to Weber) enamel coating does bugger all to insulate the coke can steel they are made of.
  3. supasaiyan
    supasaiyan Member
    Nov 17, 2006
    4,340
    3000
    In the latest aldi catalogue, they got some bbq stuff. Like a gas smoker, some woodchips, meat thermometer
  4. josh1990
    josh1990 Member
    Mar 18, 2014
    1,251
    Albury, NSW
    Bought 5 more yesterday - down to $8 :thumbup:
  5. NSanity
    NSanity Member
    Mar 11, 2002
    17,472
    So I cooked an Aus "packer" brisket.
    Things I learned.
    1. CharGriller smokers couldn't leak more than a sieve.
    2. Australian Butchers are unable to cut US cuts. It had bones on it - pretty sure it didn't have a point on it.
    3. Waking up every 1.5 hours to feed a leaky firebox/cooker is a pain in the ass.
    4. I'd hate to be my neighbours when I smoked up some apple chips after the brisket was resting in an Esky, to smoke some pre-cooked sausages.
    I have access to a welder and handy people that way. Short of welding up all the gaps - what else can i do to mod this gifted Char Griller into something that doesn't leak like a sieve?
    Confident I can fix the butcher problem if i can get a proper cut description...
    Also confident i can get 2-3 hours sleep between feeds w/ pitmasterIQ and a cooker that doesn't leak.
  6. Stooge007
    Stooge007 Member
    Aug 22, 2006
    9,898
    The Shire, Sydney
    buy the remainder
    sell one to me
    sell the rest to other OCAU members
    profit?
  7. connico
    connico Member
    Jan 30, 2004
    3,332
    1. Non reactive heat proof (300°) seals will do the trick. Welding is good too but you still need seals. As you've used the unit, make sure its clean before you apply them.
    2. Yeah cut description would be good or a picture of the cut :)
    3. Stay up all night with a few mates and talk shit?
  8. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    137,093
    Omicron Persei 8
  9. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,274
    Expired as off an hour ago, it seems.
    sgtraven
    sgtraven Member
    Sep 10, 2004
    3,042
    Vic, Glenroy
    If people are interested i may be able to get someone to match that price
  11. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    137,093
    Omicron Persei 8
    Bugger : ( Sometimes you really have to be quick with this stuff.
  12. broccoli
    broccoli Member
    Feb 21, 2010
    19,534
    If anyone in Perth NOR is looking at getting a Weber, they've got Weber people cooking stuff outside the Getaway Outdoors camping shop on Amelia Street Balcatta (I think it's balcatta, cnr amelia and wanneroo road). They've got the Weber Qs and some other huge one.
  13. brettmo86
    brettmo86 Member
    Jul 11, 2004
    2,967
    Gold Coast
    Noticed barbecues galore have a "billabong" 57cm kettle for sale at $69 (usually $100).
    Anyone had any experience with these?
    Better off saving for a weber or waiting for a second hand to come up?
    Cheers
  14. miicah
    miicah Member
    Jun 3, 2010
    5,778
    Brisbane, QLD
    I think I paid $20 for my "weber" from Gumtree, just needed a coat of BBQ paint on the inside of the lid. Installed my own thermometer and it's lasted me around 3 years.
  15. mmBax
    mmBax Member
    Oct 26, 2011
    3,038
    Go and have a look is my recommendation. It'd probably be similar to the cheapies you can get at bunnings for 40 dollars. They'd do the job for a few months, but because it's made out of cheap crap steel they'll fall to bits and rust out, probably only last a year or two.
  16. Scandrew
    Scandrew Member
    Jan 11, 2003
    2,426
    Better off spending a little bit extra for the Weber or picking one up 2nd hand on Gumtree/eBay.
    I've had experience with a few lower priced BBQ's and have found Weber's to generally be just that little bit extra better in quality/longevity. If it's going to last you a few years what's a couple of dollars.
  17. Stooge007
    Stooge007 Member
    Aug 22, 2006
    9,898
    The Shire, Sydney
    i have a cheap knock-off weber kettle, doesn't seem to seal 100%, but doesn't really affect it much, can still roughly hold 225*F without too much effort
  18. StratosFear
    StratosFear Member
    8,058
    Melbourne, Australia
    Thought I'd ask here rather than starting a new thread.
    I just got a Weber Original Kettle with the intention of trying some slow cooked deliciousness in it.
    Just wondering if there are any "must have" gadget that I should look at. I'm interested in getting or making a wifi temperature gauge and possible a stoker. I've got a spare Raspberry Pi sitting around and just ordered a couple of thermocouples to play with. Anything else? Any good plans to look at?
  19. Scandrew
    Scandrew Member
    Jan 11, 2003
    2,426
    a charcoal chimney always makes charcoal cooking that little more convenient
    sgtraven
    sgtraven Member
    Sep 10, 2004
    3,042
    Vic, Glenroy
    must haves
    - water pan for using with snake method
    - wireless thermometer (most start with maverik)
    re using the rasberry pi as a stoker its a pretty big project but good on you.
    there are a few great guides on how to build one but if you are interested there is also an aussie manufacturer that is now building one called the smartfire
