BIG GUIDE TO BBQ (What to buy Help)
Discussion in 'Geek Food' started by sgtraven, May 27, 2014.
  1. iMomOx3
    iMomOx3 Member
    Dec 13, 2008
    1,376
  2. JIM-NUFC
    JIM-NUFC Member
    Jan 17, 2012
    7,333
  3. josh1990
    josh1990 Member
    Mar 18, 2014
    1,668
    Albury, NSW
    It's not the size, it's how you use it!
  4. the916man
    the916man Member
    May 3, 2003
    56
    Weber GA is ideal for skewers and you will prob fit more on it than a mini kettle
    There isn’t a lot of waste ash to get rid of , just bag it and throw it out
  5. iMomOx3
    iMomOx3 Member
    Dec 13, 2008
    1,376
    Well I ended up getting myself a Weber Q2000 over the weekend at Rays Outdoor on sale for $359 but got it a little more down to $339 + I bought the Q cover @ 20% off.
    Might need to invest in the cleaning brush as I heard it makes a huge difference using their proprietary one - I didn't have too much trouble cleaning my Q with my generic brush from Bunnings but if it makes it easier then why not?
    I didn't bother with the half hot plate for now because I'm on the balcony using a gas bbq, I can easily get the misses to cook onions / mushrooms that we'd usually use the hot plate on inside the kitchen (within 6m away). Can't seem to find a reason to use the hotplate at this stage.
    Was pretty successful first time cooking some wings and porterhouse steaks on. I've definitely got to get used to the closed hood cooking and controlling the temps/timing. But I can definitely say it trapped the juices in my wings which was really good. Anyone got tips on where on the temp dial I should have it set / how long and do I even bother to flip wings? Or any other meats guides/tips?
    Thanks in adv!
  6. d3vour3r
    d3vour3r Member
    Jul 27, 2012
    322
    just be careful with the glass on ur balcony. i had a glass balustrade balcony once and my bbq cracked it from the heat. have it up against the wall.
  7. iMomOx3
    iMomOx3 Member
    Dec 13, 2008
    1,376
    I have the Q at the end of the balcony against the wall with the water pipe... that would be fine yes?
  8. d3vour3r
    d3vour3r Member
    Jul 27, 2012
    322
    yeh should be fine. my glass cracked from my kettle webber being abour 40cm from it. the Q wont get nearly as hot, but keep it as far away as possible. the glass is probably safety glass double thick lamiated or whatever to be BCA compliant, and yeh it aint cheap to replace.
  9. NSanity
    NSanity Member
    Mar 11, 2002
    18,901
    Frankfurt, Germany
    Should I sell my two webers and buy a Kamado? If so, which one.
  10. the916man
    the916man Member
    May 3, 2003
    56
  11. Munki
    Munki Member
    Jul 16, 2008
    1,876
    Looking at getting my first Kettle bbq, and was going to jump straight into a Weber original premium, but is that a wise move? I never see them on sale, but ideally would like one before the end of the year.
    Also had a look at this: https://www.barbequesgalore.com.au/napoleon-rodeo-pro-57cm-on-legs
    I liked the hinged lid. I thought that would be really useful, but I don't know much about the brand. I checked it out at a barbeques galore store and the construction seemed OK (felt solid - had a nice cast iron grill, steel heat diffuser, etc). I don't really know what else to look for though. Plus it's 20% off right now... So for a little less than the Weber premium, the Napoleon pro seems to tick a lot of the boxes.
  12. hsvguy
    hsvguy Member
    Oct 18, 2005
    3,834
    The Home Of Coopers
    My mate got one of the napoleon's, he really likes it. But you can't beat a weber in my opinion. After sales service is second-to-none, 10 year warranty, and will last forever even if you don't look after it.
    You can pick up a weber second-hand for under $100, but if buying new, i wouldn't personally bother with the premium (enclosed ash catcher), just get a regular one. You'll save over $100.
    Not sure who the weber specialist is in Sydney, but here's one from Adelaide to give you an idea on models and current colours
    https://www.rawsonseliteappliances.com.au/weber?cat=450
    Munki likes this.
  13. Munki
    Munki Member
    Jul 16, 2008
    1,876
    Cheers mate. You're probably right about Weber being the better option. They've got the legacy and after sales service. Just wasn't sure whether that enclosed ash catcher was worth the "premium", but I think it'll be good for windy days. Don't really want ash flying around - especially with kids around.
    I'm not sure who our Weber specialist is either, but I've seen them on the Mitre 10 website. Will be ordering through them for click and collect, but not sure you can specify the colour.
  14. josh1990
    josh1990 Member
    Mar 18, 2014
    1,668
    Albury, NSW
    I got a Weber Go Anywhere for Xmas from the wife. Have made some spectacular burgers on it. Definitely no good for a full bird (split) as covers too much airflow. Made some nice wings but had too much lump in and had to throw in airfryer so they didn't become lumps of charcoal themselves. Might get an offset plate for it I think, definitely a learning curve. Will also try using beads instead of the lump.
  15. hsvguy
    hsvguy Member
    Oct 18, 2005
    3,834
    The Home Of Coopers
    You can also get risers for them to turn it into a rotisserie, or to fit a whole chicken/roast.
    https://rubandgrub.com.au/collections/bbq-accessories
    If you're on facebook, join the page weber GA life.
    josh1990 likes this.
  16. josh1990
    josh1990 Member
    Mar 18, 2014
    1,668
    Albury, NSW
  17. sanjay
    sanjay Member
    Mar 10, 2004
    16,472
    Coburg, Melbourne
    Looks like this thread needs a revival - I bought a second hand baby Q off Facebook today and my partner has cracked the shits - insists it's too small (she's been eyeing off a Family Q but I think they're too big for just the two of us).
    So I need to win her over. Hit me with your Baby Q recipes please :leet: the easier the better, as I'm not really a cook (part of the reason I got the Q, to do a bit more in that respect).
  18. Stooge007
    Stooge007 Member
    Aug 22, 2006
    13,264
    The Shire, Sydney
    what sort of meat/style of cooking does she like?
  19. sanjay
    sanjay Member
    Mar 10, 2004
    16,472
    Coburg, Melbourne
    She's pretty easy/flexible to be honest. We haven't had a barbeque at all for quite a few years (never had an ideal/safe place to set one up). I want to do a whole roast chook in it just to prove to her it's not too small :lol:
  20. Stooge007
    Stooge007 Member
    Aug 22, 2006
    13,264
    The Shire, Sydney
    beer can chicken might be a good place to start then, not sure if there's the room to stand the chicken upright though?
    sanjay likes this.
