Bigger res = lower temps??
Discussion in 'Extreme and Water Cooling' started by electro rc, Jun 18, 2013.
  1. electro rc
    electro rc Member
    Mar 18, 2010
    2,343
    Wide bay, QLD
    Hi, I'm planning on redoing my loop soon (when I get a blocked 580/680) and I'm thinking of adding a big res (custom jobbie) to help keep temps down. My reasoning is that more water = more to heat up = cooler all round temps. Is this correct??
    Cheers,
  2. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    in your gearbox...grindin
    it is correct, yet it is not.
    Long story short, without the physics ect:
    You're increase of water volume will only 'delay' the enevitable of the whole water loop reaching it's peak temperature.
    to sufficiently be able to keep temps lower you must have a very large surface area for the heat to radiate from the 'hot' water to the 'cooler' surroundings eg: air. Or, just have higher CFM fans.
    in other words, either get a seriously large res, like a beer keg and let the heat radiate into the room naturally, or get a larger radiator, which will also require more water in the loop.
    I could work it out for you if i get some more details...such as
    thermal output of the CPU/GPU/pump
    pump's output in litres per minute
    total water in the loop
    radiator's surface area in mm^2
    So, just a larger res, say 2litres is only just slightly delaying the heating of the entire loop
    electro rc
    electro rc Member
    Mar 18, 2010
    2,343
    Wide bay, QLD
    The best I could do for that is guess:Paranoid:. I think I'll just shove another 240 rad in if the 680 brings temps too high, or get better fans (currently using 1x H100i stock fan and 2x enermax T.B.silence). Or go back to air cooling... HA, as if :p.
    Cheers,
  4. HeXa
    HeXa Member
    Jul 7, 2001
    10,211
    Canberra, ACT
    RS360 does my 680+2500K fine
    but then my ambient temps are much lower due to location :p
  5. havabeer
    havabeer Member
    Dec 12, 2010
    8,911
    maybe just throw a couple of ice cubes into the res before use, as mentioned, going to need a large res for this to happen
    electro rc
    electro rc Member
    Mar 18, 2010
    2,343
    Wide bay, QLD
    I really don't think temps will be too bad, I'm only going 20c above idle temps at full load anyway (30c-50c) and I don't really mind my CPU/GPU running at temps up to 70c. If they go over 70c, that's when I'll chuck in another rad or down clock my CPU.
    Cheers,
  7. Jakusonfire
    Jakusonfire Member
    Jun 16, 2012
    512
    Newcastle
    Reservoir size makes no difference to temperatures.
    All it does is slow down the speed at which the system moves from its idle water temp to the full load water temp.
    If your loop holds 2 litres of water it takes a 300 Watt system approx 4 minutes to heat the water by 10C, an extra litre of water adds about another 2 mins.
    That is assuming that you have no fans running to fight heating but either way the difference is negligible.
    Although the system warms more slowly it also cools back down equally slowly.
    Only extra radiator space or faster fans/more airflow will reduce temperatures.
  8. mtma
    mtma Member
    Aug 12, 2009
    7,291
    The only real argument I can see for a larger res is component life. Longer time constants w.r.t. temperature will always help reduce the thermal stress on components.
    One other situation where you might consider using a large reservoir is if you had a system that has something that comes completely on and then goes completely off to cool, such as a basic chiller unit. But it's pretty unlikely and for such scenarios your fluid turnover time typically needs to be greater than 5 minutes. Pretty easy to end up needing a 60-100L res :lol: the little bottles put into PC's will look like nothing in comparison !
    Luckily people who use chillers just want the absolute maximum level of coolness and don't encounter this problem :cool:
  9. Jakusonfire
    Jakusonfire Member
    Jun 16, 2012
    512
    Newcastle
    The CPU and GPU's themselves will still pretty much instantly change temp from idle to load, ... eg 30C to 60C for CPU's
    The extra few degrees added as the water changes temp are pretty insignificant compared to that. The speed that that happens might make a statistical difference to component life but I doubt it.
  10. SyKRyD
    SyKRyD Member
    Feb 13, 2009
    193
    Perhaps the only exception is a reservoir like this
    Even then you'd need good airflow and difference in temps would probably be negligible.
  11. NinjaStickman
    NinjaStickman Member
    Jul 23, 2012
    285
    West Hobart, TAS
    Pretty much bang on, time taken to heat the fluid is proportional to the volume. You see, now that I have had a chance to procrastinate,
    I give you....
    Little bit of awesome to lighten your day
  12. warhead
    warhead Member
    Jun 7, 2004
    718
    So if you don't run your PC 24/7, you can theoretically get a res so big that before the water even reaches peak temp you would already shutdown for the day :p
    Just for shits n giggles, what volume would this theoretical res need to be? Assume the PC is on for no more than 12hrs straight
  13. JonnoHR31
    JonnoHR31 Member
    Jan 4, 2012
    195
    As long as the res had sufficient heat dissipation to disperse all the heat over the 12hrs the PC was off and return the water to ambient temperature then yes it's possible. No idea exactly how much water that would take but it'd be a hell of a lot if you're talking about 12hrs straight at full load with multiple GPUs.
  14. NinjaStickman
    Jul 23, 2012
    285
    West Hobart, TAS
    You would need more details,
    Specific heat and density of the coolant and power drawn by system versus power dissipated in the radiators.
    Not impossible, but not my cup of tea either :)
    Aye, you also need to realise that this works both ways. say it took 12 hours to change the temperature of your super-massive-res by 15degrees from ambient, it would then take 12hours to cool down those 15degrees. So unless you had the water still being cooled by the rads with the PC off, you're on a pretty strict use cycle :D
  15. Sunder
    Sunder Member
    Apr 26, 2012
    4,653
    Alternatively, the start of your loop could be a tap, and the end of your loop a sink... Just eliminate the need for a radiator at all. If you live in an apartment, water isn't metered ;)
  16. NinjaStickman
    Jul 23, 2012
    285
    West Hobart, TAS
    You sir, are a genius! .... no radiators, no pumps...
