Bigpond rolling 100Mbit Cable nationwide
Discussion in 'Networking, Telephony & Internet' started by [KEi]SoVeReIgN, Nov 23, 2011.
  1. Abraxsus
    Abraxsus Member
    Dec 6, 2002
    77
    I suppose is does....
    I can't for the life of me remeber, I'll have to call and check (still in the cooling off period right now)
  2. Abraxsus
    Abraxsus Member
    Dec 6, 2002
    77
    I think its this: Netgear CGD24N
  3. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    thats a router, im not having a dirty POS like that in my house.
    Looks like the 1 port modem is a sb5101, thank god for a decent modem.
  4. Abraxsus
    Abraxsus Member
    Dec 6, 2002
    77
    I'm certainly not reading good things about the Netgear CGD24N right now. I think I need to change it.
    [KEi]SoVeReIgN
    [KEi]SoVeReIgN Member
    Feb 20, 2002
    8,583
    You don't have the option for a single port modem anymore..
    I just had bigpond installed at my new place and they supplied the netgear above :thumbdn:
    But I've just turned off NAT and used an airport extreme - Performance is just as good as my previous house (with single port sb5101)
  6. Abraxsus
    Abraxsus Member
    Dec 6, 2002
    77
    Thats interesting, a single port is still an option on the form. I'm going to call and find out exactly what options there are, might have to wait till tomorrow though (wait was too long earlier).
  7. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    question is will they provision a sb5101 as byo? i got like 20....
  8. martino
    martino Member
    Mar 8, 2005
    1,225
    If it was originally a BP modem - yes.
    If its an Optus one - no.
  9. flinchy
    flinchy Member
    Jan 18, 2007
    6,362
    Northlakes
    naw, you just pay for the $20 plan that includes line rental :).
    only mobile provider i've found that doesn't have great coverage would be optus. even rural has 3 bars on telstra mobile.
    i work in telecommunications :/
  10. trackhappy
    trackhappy Member
    Dec 29, 2009
    2,364
    Redbank Plains, QLD, 4301
    I read the thread title and was: :shock:
    Now that I realize they're not actually expanding the infrastructure (and we're left in the lurch for at least another 5 years until the NBN rolls around, if the labour government still exists by then), I'm more like: :mad:
  11. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    Why do they care? It will get a BP image the minute you plug it in anyway
  12. caspian
    caspian Member
    Mar 11, 2002
    11,614
    there is no "imaging". the issue is MAC address range whitelisting at the hub.
  13. Duideka
    Duideka Member
    Jun 21, 2009
    309
    Every ISP's section is full of complaints on WP, even Internode :thumbup:
    Been with TPG for a year, downloaded at least 2TB so far and no complaints about network quality. I was with iiNet previously also, and honestly feel like TPG's network is smoother for me. Although, with that said, iiNet have changed their network significantly since I left - I don't know if iiNet would be smoother or not for me now.
  14. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    So what wrong with adding new ones?
    by imaging what ever prov system they use will tftp a firmware out once its connected.
  15. brad89
    brad89 Member
    Jul 17, 2008
    601
    Optus SB5101 modems will work on Bigpond. If you have problems with the captive portal (some do every now and then for whatever reason) L2 TS will be able to add it manually.
  16. Speedster20
    Speedster20 Member
    Jan 3, 2002
    253
    The Vines, WA
    If you get put on Ultimate (100Mbps) at the moment you'll either get a Cisco EPC3925 or (more likely) a Netgear CG3100D. Both are routers, they don't offer a straight EuroDOCSIS 3.0 modem.
  17. caspian
    caspian Member
    Mar 11, 2002
    11,614
    where's the advantage to them in doing so?
    easier solution - just don't allow them in the first place.
    they will "work" in that they are compatible from a technology standpoint. L3 can whitelist the MAC manually on the hub, L2 certainly cannot. I know, I briefly did the L3 job.
  18. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    fail design is fail.
  19. brad89
    brad89 Member
    Jul 17, 2008
    601
    I'm saying they will work but there will be rare cases where you need it manually done, I'd bet a large majority work straight away via the captive portal. You seem to be saying the opposite but whatever, not many people will care about them soon :lol:
    I was told L2 but have never needed it myself so I just assumed it was correct.
  20. caspian
    caspian Member
    Mar 11, 2002
    11,614
    not from their point of view. only from yours. ;)
    I'll bet exactly 0% of them do, as the MAC address whitelisting is done on known address ranges. not in known range = go jump.
    I don't care about the long term survivability of either the HFC technology or Bigpond. the former is a dead legacy technology, the latter is a dead business unit of a company mired in the past.
