Bitspower Fitting Advice
Discussion in 'Extreme and Water Cooling' started by e2ek, Aug 8, 2009.
  1. e2ek
    e2ek Member
    May 31, 2003
    716
    Sydney Destination: ?
    I am looking at doing a bulk purchase of fittings for my new project. As I am a first time WC'er I need some advice on BP fittings before I make my purchase.
    Can someone explain the difference between these two products. There is an obvious physical difference, though I am not sure what the difference in functionality is.
    http://www.gammods.com.au/store/index.php?main_page=product_info&products_id=1569
    http://www.gammods.com.au/store/index.php?main_page=product_info&products_id=1570
    Also, do 7/16"-5/8" BP Compressions screw nicely into EK Multioption Res's? I think I remember reading that large compression fittings do not seal real well against the end caps of the Multioptions and extensions are sometimes needed to ensure a water tight seal.
  2. retrobot
    retrobot Member
    Apr 12, 2009
    43
    the triple rotary will be able to rotate at the neck, whilst the other shiny silver one will only rotate at the middle. Unless someone can correct me on that.
  3. JTF
    JTF Member
    Aug 27, 2005
    561
    Brisbane 4118
    With the fitting in the first link, it twists in 3 places, the knurled ends rotate inside the fitting.
    e2ek
    e2ek Member
    May 31, 2003
    716
    It seems so obvious now that you both have pointed it out :o.
    Thanks very much :thumbup:
