Blade Mini MKII
Discussion in 'Modding Worklogs' started by Defyant, Dec 3, 2018.
  1. Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Defyant Modded "Tail" Lights!
    Ive never built a mini PC and thought it would be handy to have one around the house.
    Some thing portable and go from room to room and workshop if needed.
    The first build of the housing used a 120 mm front fan...but decided to go larger to a 140 just to make it look more outrageous.
    The layout will be simple almost the standard now for these SFF Builds. Except for the 140 front intake.
    DSTM (Dougie), mad_mic3 and museumman like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    To keep the front clean with no holes or screws i'm using a sliding bracket system for the front fan.
    This also keeps the case a bit more modular for fan/AIO installs.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    For the "guts" im still not 100% but for some older hardware will do for now.
    The layout is in 2 chambers, MB/ PSU on one side and GPU/ RES / SSD's on the other.
    The the GPU side a simple slider mech was made to hold the card in place a riser cable will be added with a secondary mount mech.
    Still not sure if i will do a modded AIO system with res or just go with a off the shelf. Either way there is plenty of room.
    The PSU can be flipped to either help with exhaust of drag clean air through the sides... i may go with
    full mesh side panels for this one.
    Anyways mtc soon.
  4. Themaveriq
    Themaveriq Member
    Feb 11, 2017
    16
    Looking good mate, very interested to see how this turns out.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Cheers mate tyvm :thumbup: So am i :) just making this up as i go... pretty much as normal :D
    A quicky update,
    Ive re-trimmed the outer blades to suit the new design
    The modified blades are hard glued to the housing
    The last outer 2 blades are also hard glued the outer edges.
    Gluing them to the outer edges for a flush fit gives a cleaner look
    Adding the larger 140 mm fan has a better over all look and fill up the front of the case.
    MTC soon :thumbup:
  6. Tazor
    Tazor Member
    May 23, 2010
    2,372
    Canterbury, 3126
    Could you do a Flex ATX mount under the GPU to allow additional clearance over the Motherboard?
    SFX PSU's get hot so I feel like that placement could affect the temperatures on the board.
    Still, love the case with your signature blade style!
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Cheers as always Tazor tyvm mate :) On the top mount bracket for the GPU i added extra threaded screw holes. It was done to cover if i add a different GPU down the track and to be able to offset the card incase of thickness differences.
    But it does allow me to step the card out maybe another 10mm before bumping the side panel. The bottom lock allows the card to freely slide and the riser cable would just hang free.
    I'm still not sure how i will handle the side panels this time around. I thought about large full mesh inserts... but if temps allow i would really like to go flashy , maybe tinted inserts with a theme.
  8. sammy_b0i
    Jun 29, 2005
    3,816
    ACT 2913
    Love it. Want one with slight modifications! Will keep an eye out for the finished products. Always wanted to commission a Defyant-built case since the Turbine HP's... :)
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Cheers as always sammy :D be my pleasure mate :thumbup:
    I did get a small update done today !
    Just trying different things for the side panel.
    This time ive made a proper type side panel from 6mm and done double routed inner and outer edges, this should give some "depth" to the sides rather than just a flat panel.
    For now i'm testing out some slight tinted windows. I may go clear or poss orange. But i think the contrast of the white on tint is a modern look.
    I'm thinking a hook lock and single rear screw system this time round to hold them in place.
    The sides were a bit of work with all the extra shape.
    The tinted is cut to the exact same size as the opening this will make it a large press fit key.
    Next is the glue the window to the side panel.
    And give it a test fit.
    I was a little bit worried that the window would be a little bit too light.....
    So i chucked in some hardware and can safely say that the tint is more then dark enough :thumbup:
    Might take a break till the weekend :thumbup:
  10. zebu
    zebu Member
    Jul 28, 2001
    918
    Albury
    I was trying to figure out what the design reminded me of with the wing on the back then it came to me
    looks great.
    Defyant likes this.
  11. DSTM (Dougie)
    DSTM (Dougie) Member
    Jun 2, 2018
    652
    Western Sydney
    Be great to have a "Limited Edition" case, made by the "Mod Master".:thumbup:
    Defyant likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    You see it ! for sure man , the Design is from old style car design !
    So much of what i do is sourced from that style ) tyvm for seeing it :thumbup::thumbup:
    Cheers Dougie ty mate:thumbup: i was just thinking theres a few things i'd like to do different if i go round again.
    You may end up with a mk2 :)
    zebu and DSTM (Dougie) like this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Gettin there slowly :)
    A big thanks to Dougie for helping me out with a TT riser cable bud your a legend :thumbup::thumbup:
    Ive gone with the older style corsair hydro AIO as it still uses one of the lowest profile block pump combo.
    As this is a 120mm cooler and im using a 140 fan in the front ive made a 6mm clear adaptor and to take up some hose ive mounted the rad east west.
    I may upgrade this later to a 140 AIO when i upgrade the hardware .
    To help hold the GPU secure ive added some standoffs, this will also keep the back of the card off Dougie's
    donated TT riser cable :)
    For the riser cable ive also added some standoffs.
    These will connect to a L bracket that will hold the connector in place.
    The bracket is tapped and secured to the base
    And for now the bracket doubles as a SSD mount as well.
    Some cable tie tidy up work
    Add in the Corsair RGB crap
    And finally fire it up and load some windows.
    Still got a ways to go.... need to come up with a new system to lock the side panels on and add maybe a
    usb port and gotta add a power button.
    juzz86, mad_mic3 and DSTM (Dougie) like this.
  14. DSTM (Dougie)
    Jun 2, 2018
    652
    Western Sydney
    I like it very much, mate.Love the ribs.
    I like the Corsair RGB bling. Makes it come alive.
    So much in such a small space. Clever.
    I would hide a small start button between the ribs underneath.
    Don't want to spoil the lines.:thumbup:
    Defyant likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Cheers Dougie ty mate :thumbup:
    I got a bit of motivation this weekend :D Added a small rear exhaust fan to help move some air... altho really not needed.... but every bit helps !
    And went with Dougie's suggestion and added the power button between the ribs.. but at the rear the rear of the case... i decided i did not want to spoil the front at all.
    So far ive made 3 different sides.... but have decided to just go with clear full side.
    Also decided that i didnt want the fan adaptor plate to be clear and gave it a few coats of matt black
    This keeps the inside a bit more uniform :)
    Tazor, juzz86, Themaveriq and 2 others like this.
  16. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,458
    Nulkaba
    looking good as allways, good to see your still getting shed time:)
    Defyant likes this.
    Defyant
    Defyant Member
    Mar 11, 2004
    1,395
    Cheers mic not as much as i'd like :D Hope you are getting better mate :thumbup:
    mad_mic3 likes this.
