Blue Screen on wake up
Discussion in 'Troubleshooting Help' started by badT18, Jan 29, 2010.
  1. badT18
    badT18 New Member
    Jan 27, 2010
    21
    Ok im just reformated my computer and now im getting a blue screen everytime my computer wakes up from sleep mode.
    I was getting blue screen before i formated but wasnt when i woke it up i was getting them randomly (mostly when i was downloading at high speeds)
    i was thinking i am getting blue screen because of faulty RAM. i got 4x 1GB kingston ram. so manualy taking out each stick of ram and testing wouldnt be ideal because i got crossfire and there is on room at all in my case so taking out the ram would mean taking the video cards and hard drives out aswel.
    i was also thinking it might because my netgear usb driver (cause it seems to get blue screen when the card is in use.
    i did google the blue screen code and it returned something about ATI drivers so i was also thinking of maybe its the graphic cards.
    But i have no idea on how to find the problem. (even maybe its win 7 problem because i have had 1 blue screen running vista for a year.)
    this is the error log
    The computer has rebooted from a bugcheck. The bugcheck was: 0x00000116 (0xfffffa80055c94e0, 0xfffff88004abf7f8, 0x0000000000000000, 0x0000000000000002). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: .1001
    1. Is there any tool i can test the RAM (i have done the windows RAM test and it came back fine, i also tryed mem test but i think thats for ddr 1 not ddr 2 so didnt work)
    2. i got kingston normal DDR2 800mhz Ram what is the warranty on thoses, i know some of there products are life time.
    3. Any other way i can test my system from this problem im open for any tools, app ect
  2. Korrode
    Korrode Member
    Jan 30, 2010
    11
    Victoria
    http://www.memtest86.com/
    Just download the ISO, burn it to a CD, and boot your system from the CD, it'll do an extensive memory test, best to leave it running for some hours.
    badT18
    badT18 New Member
    Jan 27, 2010
    21
    i did a memtest for 9 hours and got 7 passes
    i updated my ATI rivers still didnt work
  4. Dave2972
    Dave2972 Member
    Nov 6, 2007
    1,075
    I had similar issues in 7 and Vista so I set wakeup in BIOS to S1 from S1/S3 and the problem went away.
  5. TMM
    TMM Member
    Mar 29, 2005
    7,481
    Going into S1 totally defeats the purpose of sleeping the computer though. You might as well just turn the monitor off.
    Sounds like a driver problem to me. I'd strip down the computer to bare essentials (mobo, cpu, ram, 1 gfx card, 1 hdd, psu, nothing else) and see if the problem goes away. If it doesn't, try different graphics, audio and network drivers (remember newer isn't always better!).
  6. FireTech
    FireTech Member
    Feb 6, 2005
    1,651
    Sunny Sydney
    Try down-dating your ATI drivers to the 9.08 version.
  7. grss1982
    grss1982 Member
    Jul 23, 2004
    302
    Philippines
    Did you update the bios of your mobo? I thought this issue had somehting to do with ACPI or something.
    EDIT:
    Might be worth a read: http://www.computerperformance.co.uk/windows7/windows7_sleep_problem.htm
  8. OldnBold
    OldnBold Member
    Oct 5, 2004
    4,261
    Sunshine Coast
    What are the rest of your computer specs (including Operating system)?
